I've been trying to solve this issue and came to a dead end. I will need some advice for this.
I do have a CSV file. Below is just sample data, but the file has like up to thousand lines. Below is the sample file:
"timestamp","name","type","value","date"
"2019-11-27 05:42:45.000","bill.acme.com","ns","ns-1468.awsdns-55.org","201911"
"2019-11-27 05:42:45.000","bill.acme.com","ns","ns-1777.awsdns-30.co.uk","201911"
"2019-11-27 05:42:45.000","bill.acme.com","ns","ns-258.awsdns-32.com","201911"
"2019-11-27 05:42:45.000","bill.acme.com","ns","ns-638.awsdns-15.net","201911"
"2019-11-27 05:51:28.000","bills-record.global.acme.com","a","10.144.152.62","201911"
"2019-11-27 05:51:28.000","bills-record.global.acme.com","a","10.144.126.177","201911"
"2019-11-27 05:51:28.000","bills-record.global.acme.com","a","10.144.135.205","201911"
What I'm trying to achieve here is, if name,type and date has the same value, the output should be a single name value with multiple IP addresses/string as it's value. However the value of IP/string should not be a duplicate. The values can amount from 1 to n.
I've tried using IF statements but to no avail. I know by using add_field, it will automatically create an array if the field is not, but I can't get it to grab multiple IP addresses.
The sample JSON output I'm hoping is as below:
"type" => "ns",
"date" => "201911",
"name" => "bill.acme.com",
"@version" => "1",
"timestamp" => "2019-11-27 05:42:45.000",
"value" => [
[0] "ns-1468.awsdns-55.org",
[1] "ns-1777.awsdns-30.co.uk",
[2] "ns-258.awsdns-32.com",
[3] "ns-638.awsdns-15.net"
"type" => "a",
"date" => "201911",
"name" => "bills-record.global.acme.com",
"@version" => "1",
"timestamp" => "2019-11-27 05:51:28.000",
"value" => [
[0] "10.144.152.62",
[1] "10.144.126.177",
[2] "10.144.135.205"
Thanks!
