Problem with cipher in beat input
I have a problem with the beat input in logstash.
When i starting logstash, the beat input has an error with the cipher.
This is the error in log :
Pipeline aborted due to error {:exception=>#LogStash::ConfigurationError: Cipher TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384 is not available>, ...
This my Logstash and java version :
logstash 5.0.2
jruby 1.7.25 (1.9.3p551) 2016-04-13 867cb81 on Java HotSpot(TM) 64-Bit Server VM 1.8.0_77-b02 +jit [linux-amd64]
java 1.8.0_77 (Oracle Corporation)
jvm Java HotSpot(TM) 64-Bit Server VM / 25.77-b02
This is my logstash config :
beats {
port => 5001
host => "X.X.X.X"
type => "log"
ssl => true
ssl_certificate => "/etc/pki/tls/certs/logstash-forwarder.crt
ssl_key => "/etc/pki/tls/private/logstash-forwarder.key"
I do not understand where the problem comes from.
Do you have an idea?
Thanks.
I noticed the same on my host.
I added cipher_suites => [ "ECDHE-RSA-AES256-GCM-SHA384" ] to logstash.conf but get the same error. (logstash 5.0.2)
$ java -version
openjdk version "1.8.0_111-internal"
OpenJDK Runtime Environment (build 1.8.0_111-internal-alpine-r0-b14)
OpenJDK 64-Bit Server VM (build 25.111-b14, mixed mode)
Receiving the same error:
Pipeline aborted due to error {:exception=>#<LogStash::ConfigurationError: Cipher `TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384` is not available>...
Versions:
logstash 5.0.2
logstash-input-beats 3.1.12
openjdk version "1.8.0_111"
OpenJDK Runtime Environment (build 1.8.0_111-b15)
OpenJDK 64-Bit Server VM (build 25.111-b15, mixed mode)
Tried lesser cipher suites and had the same error with those.
Running logstash in debug mode, I get the following:
[DEBUG][io.netty.handler.ssl.OpenSsl] Failed to load netty-tcnative; OpenSslEngine will be unavailable, unless the application has already loaded the symbols by some other means. See http://netty.io/wiki/forked-tomcat-native.html for more information.
java.lang.IllegalArgumentException: Failed to load any of the given libraries: [netty-tcnative-linux-x86_64, netty-tcnative-linux-x86_64-fedora, netty-tcnative]
I can't seem to find any of those libraries for CentOS 7
Had this issue with a system, and found the problem was /tmp was mounted with noexec option.
Removing the noexec option and rebooting fixed the issue on my system.
It looks like logstash puts a copy of the libnetty-tcnative dynamic library so in /tmp and tries to load it from there which the noexec option blocks. Loading code from /tmp seems like a security risks.
EDIT: the code putting the library in TMP is in netty which is used by logstash.
EDIT 2: maybe the tmp path can be made more sane in logstash's jvm.options file by adding a line
-Dio.netty.native.workdir=some path
Indeed, the /tmp partition with noexec option is the problem.
I have not removed noexec option in /tmp partion for security reason. The solution of jvm.options file is the best solution.
I added the io.netty.native.workdir option in the jvm.options file and the SSL works good now.
Thank you for your help !
