Problem with crashing UDP Sender in Logstash
We use logstash to send UDP data through a secure interface that only allows communication in one direction. It worked very well intil I introduced a little more load to it.
Running ELK stack 6.6.0 with filebeat and auditbeat at the same version.
Now I get this error:
----- ERROR MESSAGE ----- Start
logstash[16381]: [2019-04-30T09:21:57,882][FATAL][logstash.runner ] An unexpected error occurred! {:error=>#<Errno::EMSGSIZE: Message too long - No message available>, :backtrace=>["org/jruby/ext/socket/RubyUDPSocket.java:438:in send'", "/usr/share/logstash/vendor/bundle/jruby/2.3.0/gems/logstash-output-udp-3.0.6/lib/logstash/outputs/udp.rb:24:inblock in register'", "/usr/share/logstash/vendor/bundle/jruby/2.3.0/gems/logstash-codec-json-3.0.5/lib/logstash/codecs/json.rb:42:in encode'", "/usr/share/logstash/vendor/bundle/jruby/2.3.0/gems/logstash-output-udp-3.0.6/lib/logstash/outputs/udp.rb:31:inreceive'", "/usr/share/logstash/logstash-core/lib/logstash/outputs/base.rb:89:in block in multi_receive'", "org/jruby/RubyArray.java:1734:ineach'", "/usr/share/logstash/logstash-core/lib/logstash/outputs/base.rb:89:in multi_receive'", "org/logstash/config/ir/compiler/OutputStrategyExt.java:114:inmulti_receive'", "org/logstash/config/ir/compiler/AbstractOutputDelegatorExt.java:97:in multi_receive'", "/usr/share/logstash/logstash-core/lib/logstash/pipeline.rb:373:inblock in output_batch'", "org/jruby/RubyHash.java:1343:in each'", "/usr/share/logstash/logstash-core/lib/logstash/pipeline.rb:372:inoutput_batch'", "/usr/share/logstash/logstash-core/lib/logstash/pipeline.rb:324:in worker_loop'", "/usr/share/logstash/logstash-core/lib/logstash/pipeline.rb:287:inblock in start_workers'"]}
----- ERROR MESSAGE ----- Stop
------------- CONFIGURATION ---------- Stop
We have a configuration that looks like this:
Server1
filebeat/auditbeat -> logstash -> UDP to server 2
Logstash configuration:
beats {
port =>
ssl => true
ssl_certificate => ""
ssl_key => ""
udp {
host => ""
port =>
codec => "json"
Server2
UDP from server 1 -> logstash -> elasticsearch
udp {
port =>
codec => "json"
type => "source_udp"
------------- CONFIGURATION ---------- Start
Any one knows what im doing wrong? Or what to tweak to make it work with more load?
Don't use UDP to send data between Logstash hosts. UDP does offer any delivery guarantees and has a limitation on size. Instead use TCP plugins or maybe even a lumberjack output paired with a beats input plugin on the receiving side.
Don´t have any choice. We use a data diode (unidirectional) between the servers for protection.
I know its not a good solution but with the data diode I have to use UDP.
For reference. A unit like this one:
Then I suspect you may need to guard against messages that are too large and filter these out.
