Problem with GeoIP using filebeat->logstash->ES->Kibana (No geo_point type)
This is my config:
  if [type] == "apache-access" {
    grok {
      match => [ "message", "%{IP:clientip} %{USER:ident} %{USER:auth} \[%{HTTPDATE:apache_timestamp}\] \"%{WORD:method} /%{NOTSPACE:request_page} HTTP/%{NUMBER:http_version}\" %{NUMBER:server_response} " ]
      add_tag => [ "web", "apache" ]
    geoip {
      source => "clientip"
      target => "geoip"
      database => "/etc/logstash/GeoLite2-City.mmdb"
      add_field => [ "[geoip][coordinates]", "%{[geoip][longitude]}" ]
      add_field => [ "[geoip][coordinates]", "%{[geoip][latitude]}"  ]
    mutate {
      convert => [ "[geoip][coordinates]", "float"]
  if [type] == "apache-error" {
    grok {
      match => { "message" => "%{COMBINEDAPACHELOG}" }
filebeat.yml
  "mappings": {
    "_default_": {
      "_all": {
        "norms": false
      "_meta": {
        "version": "5.2.0"
      "dynamic_templates": [
          "strings_as_keyword": {
            "mapping": {
              "ignore_above": 1024,
              "type": "keyword"
            "match_mapping_type": "string"
      "properties": {
        "@timestamp": {
          "type": "date"
        "beat": {
          "properties": {
            "hostname": {
              "type": "keyword"
            "name": {
              "type": "keyword"
            "version": {
              "type": "keyword"
        "input_type": {
          "type": "keyword"
        "message": {
          "norms": false,
          "type": "text"
        "meta": {
          "properties": {
            "cloud": {
              "properties": {
                "availability_zone": {
                  "type": "keyword"
                "instance_id": {
                  "type": "keyword"
                "machine_type": {
                  "type": "keyword"
                "project_id": {
                  "type": "keyword"
                "provider": {
                  "type": "keyword"
                "region": {
                  "type": "keyword"
        "offset": {
          "type": "long"
        "source": {
          "type": "keyword"
        "tags": {
          "type": "keyword"
        "type": {
          "type": "keyword"
  "order": 0,
  "settings": {
    "index.mapping.total_fields.limit": 10000,
    "index.refresh_interval": "5s"
  "template": "filebeat-*"
I had refresh de index fields... I readed ALL the threads. I dont know what to do.
Thanks in advance!
This is the map in the index...
"geoip" : {
            "properties" : {
              "city_name" : {
                "type" : "keyword",
                "ignore_above" : 1024
              "continent_code" : {
                "type" : "keyword",
              "coordinates" : {
                "type" : "float"
              "country_code2" : {
                "type" : "keyword",
              "country_code3" : {
                "type" : "keyword",
              "country_name" : {
                "type" : "keyword",
              "dma_code" : {
                "type" : "long"
              "ip" : {
                "type" : "keyword",
              "latitude" : {
                "type" : "float"
              "location" : {
                "type" : "float"
              "longitude" : {
                "type" : "float"
              "postal_code" : {
                "type" : "keyword",
              "region_code" : {
                "type" : "keyword",
              "region_name" : {
                "type" : "keyword",
              "timezone" : {
                "type" : "keyword",
Don't bother with this, the plugin creates a geoip.location field that should map correctly.
Thanks so much! Now its working. I just deleted all the old indexes for incompatibiliy types and now work fine.
