Problem with my personal index creation for platform logs
Hello, i'm trying to deploy the ECK with Beat (Filebeat) to ingest logs and Logstah to collect, for example platform logs or namespaces logs of Kubernetes cluster.
I'm using eck-operator 2.3.0 and Elastic stack in 8.3.3 inside a IBM Kubernetes Cluster in 1.23 version.
My Question is what is the the correct way to setup custom index in logstash output?
According to my understanding I need to create a index template directly in ES and use the same name in the output of the logstash. Is this not the right approach? Because I don't see the fields are index in the way I defined in the template. Below are steps I followed:
output to Elastic from Logstash:
      if ![kubernetes][namespace] {
        if [event][module] == "system" {
            hosts => ["${ELASTICSEARCH_HOST}:${ELASTICSEARCH_PORT:9200}"]
            # Default setting in Filebeat
            # index: "%{[@metadata][beat]}-%{[@metadata][version]}-%{+YYYY.MM.dd}"
            index => "filebeat-%{[@metadata][version]}-%{+YYYY.MM.dd}"
            user => elastic
            password => "${ELASTICSEARCH_PASSWORD}"
            ssl => false
            ssl_certificate_verification => false
            cacert => "/usr/share/logstash/ca.crt"
            ecs_compatibility => disabled
            manage_template => true
            template => "/usr/share/logstash/default-template.json"
            template_name => "default"
            template_overwrite => true
      else {
          index => "d-logging-logs-%{[kubernetes][namespace]}-%{+YYYY.MM.dd}"
          user => elastic
          ssl => false
    "index_patterns": ["filebeat-*", "d-logging-logs-*"],
    "template": {
        "settings": {
        "index": {
            "number_of_shards": "1",
            "number_of_replicas": "1"
        "aliases": {},
        "mappings": {}
The topic here i only receive index from filebeat but i cant receive the other index
