I just set up my first ELK cluster and I'm having a strange issue I can't track down.
I have logstash-forwarder running on the ELK host itself (set it up before I knew filebeat was a thing), and I have an external host running filebeat sending syslog messages to my ELK host. In my logstash config I have received_from set up in what looks like a fairly standard way:
if [type] == "syslog" {
grok {
match => { "message" => "%{SYSLOGTIMESTAMP:syslog_timestamp} %{SYSLOGHOST:syslog_hostname} %{DATA:syslog_program}(?:\[%{POSINT:syslog_pid}\])?: %{GREEDYDATA:syslog_message}" }
add_field => [ "received_at", "%{@timestamp}" ]
add_field => [ "received_from", "%{host}" ]
syslog_pri { }
date {
match => [ "syslog_timestamp", "MMM d HH:mm:ss", "MMM dd HH:mm:ss" ]
Messages coming from my ELK host itself show up under its hostname in Kibana just fine. However, messages coming from my other host (using filebeat) show up with %{host} in the received_from field, like they're not getting expanded by (I presume) logstash. This is from logstash's stdout:
"message" => "Mar 23 14:43:19 juno postfix/anvil[2858]: statistics: max cache size 1 at Mar 23 14:33:29",
"@version" => "1",
"@timestamp" => "2016-03-23T18:43:19.000Z",
"beat" => {
"hostname" => "juno",
"name" => "juno"
"count" => 1,
"fields" => nil,
"input_type" => "log",
"offset" => 170393,
"source" => "/var/log/mail.log",
"type" => "syslog",
"syslog_timestamp" => "Mar 23 14:43:19",
"syslog_hostname" => "juno",
"syslog_program" => "postfix/anvil",
"syslog_pid" => "2858",
"syslog_message" => "statistics: max cache size 1 at Mar 23 14:33:29",
"received_at" => "2016-03-23T18:43:27.111Z",
"received_from" => "%{host}",
"syslog_severity_code" => 5,
"syslog_facility_code" => 1,
"syslog_facility" => "user-level",
"syslog_severity" => "notice"
I'm using these versions:
- elasticsearch 2.2.1
- kibana 4.4.2
- logstash 2.0.0
- filebeat 1.1.2
All from elastic.co repositories/sources, on Debian stable.
