Problem With timestamp and timezone
Hello all,
I'm running into some problems when I'm trying to enrich data using input jdbc and filter jdbc_streaming.
This is my conf file
	jdbc {
		jdbc_connection_string => "connectionString"
		jdbc_user => "user"
		jdbc_password => "password"
		jdbc_driver_library => "postgresql-42.2.2.jar"
		jdbc_driver_class => "org.postgresql.Driver"
		connection_retry_attempts => "3"
		connection_retry_attempts_wait_time => "10"
		statement => "SELECT offer_item_id ||'-'|| TO_CHAR(pubofr_dhs_deb,'YYYYMMDDHHMISS') AS id, offer_item_id AS offeritemid, pubofr_dhs_deb AS validitybegindate, pubofr_dhs_end AS validityenddate FROM t_offer_item"
		jdbc_default_timezone => "UTC"
	jdbc_streaming {
		jdbc_user => "user"
		statement => "SELECT offer_item_id AS relativeofferid, pubofr_dhs_deb as begindate FROM t_offer_item_assoc WHERE offer_item_id_assoc = :offerId AND pubofr_dhs_deb_assoc = :offerDate"
		parameters => {
			"offerId" => "offeritemid"
			"offerDate" => "validitybegindate"
		target => "[relativeOffers]"
	elasticsearch{
		index => "activeoffers_idx"
		action => "create"
		document_type => "activeoffers"
		document_id => "%{id}"
		hosts => "elasticsearchHost"
My problem is the following, if I have the property "jdbc_default_timezone" set and have a field of type timestamp on the query of the jdbc_streaming i get this error:
Exception in pipelineworker, the pipeline stopped processing new events, please check your filter configuration and restart Logstash.
{:pipeline_id=>"main", "exception"=>"Missing Converter handling for full class name=org.jruby.RubyObjectVar3, simple name=RubyObjectVar3", "backtrace"=>
["org.logstash.Valuefier.fallbackConvert(Valuefier.java:97)",
"org.logstash.Valuefier.convert(Valuefier.java:75)",
"org.logstash.ConvertedMap$1.visit(ConvertedMap.java:35)",
"org.logstash.ConvertedMap$1.visit(ConvertedMap.java:29)",
"org.jruby.RubyHash.visitLimited(RubyHash.java:662)", "org.jruby.RubyHash.visitAll(RubyHash.java:647)",
"org.logstash.ConvertedMap.newFromRubyHash(ConvertedMap.java:69)",
"org.logstash.ConvertedMap.newFromRubyHash(ConvertedMap.java:64)",
"org.logstash.Valuefier.lambda$initConverters$11(Valuefier.java:142)",
"org.logstash.Valuefier.convert(Valuefier.java:73)",
"org.logstash.ConvertedList.newFromRubyArray(ConvertedList.java:44)",
"org.logstash.Valuefier.lambda$initConverters$15(Valuefier.java:154)",
"org.logstash.Valuefier.fallbackConvert(Valuefier.java:94)",
"org.logstash.ext.JrubyEventExtLibrary$RubyEvent.ruby_set_field(JrubyEventExtLibrary.java:99)",
"org.logstash.ext.JrubyEventExtLibrary$RubyEvent$INVOKER$i$2$0$ruby_set_field.call(JrubyEventExtLibrary$RubyEvent$INVOKER$i$2$0$ruby_set_field.gen)",
"org.jruby.internal.runtime.methods.JavaMethod$JavaMethodN.call(JavaMethod.java:741)",
"org.jruby.ir.targets.InvokeSite.invoke(InvokeSite.java:145)",
If I remove the jdbc_default_timezone property, events are processed with no problem, but i need the property there so the dates match.
Any help is welcome,
Thanks in advance.
This looks like a valid bug. The query execution is producing Ruby object that is not supported.
Can you open a full bug report on the JDBC Input Plugin, including:
  • the version of Logstash (bin/logstash --version),
  • the version of the Logstash JDBC Input Plugin (bin/logstash-plugin list --verbose logstash-input-jdbc),
  • the type of database you're connecting to,
  • a link to the database driver library
In the mean-time, you may be able to get around the bug by casting the date-type field(s) to another type in your SQL query (e.g., to a string, which could then be parsed with the date filter).
Thanks for the help, I opened the issue, you can find it here
Hello again,
i'm trying to work around the problem by casting the date in my sql to string, but I can't make it work for all events.
I use a jdbc streaming to get a list but i can't parse all elements of the list.
If i use the date filter like this:
date {
		match => [ "begindate", "yyyy-MM-dd HH:mm:ss.SSS" ]
		target => "begindate"
nothing happens.
the only way i could make it partially work was having the date filter like this
date {
		match => [ "[relativeOffers][0][begindate]", "yyyy-MM-dd HH:mm:ss.SSS" ]
		target => "[relativeOffers][0][begindate]"
but this only changes the first element and i can't repeat this for all elements cos I don't know the number of elements I get from the jdbc streaming.
Is there a way to parse all the elements on the list?
