Hi there, I have used the helm chart to install logstash onto my kubernetes cluster, however I am having problems getting filebeat to send logs to logstash.
Filebeat is running on a windows server as a service on that server, and previously had no issues sending to logstash running on a linux box. I need to move logstash onto kubernetes but filebeat logs keep showing the following:
2021-07-05T13:36:00.048+1200 INFO [publisher_pipeline_output] pipeline/output.go:143 Connecting to backoff(async(tcp://route-to-container:443))
2021-07-05T13:36:00.048+1200 INFO [publisher] pipeline/retry.go:219 retryer: send unwait signal to consumer
2021-07-05T13:36:00.048+1200 INFO [publisher] pipeline/retry.go:223 done
2021-07-05T13:36:00.049+1200 INFO [publisher_pipeline_output] pipeline/output.go:151 Connection to backoff(async(tcp://route-to-container:443)) established
2021-07-05T13:36:00.074+1200 ERROR [logstash] logstash/async.go:280 Failed to publish events caused by: EOF
2021-07-05T13:36:00.074+1200 INFO [publisher] pipeline/retry.go:219 retryer: send unwait signal to consumer
2021-07-05T13:36:00.075+1200 INFO [publisher] pipeline/retry.go:223 done
2021-07-05T13:36:00.096+1200 ERROR [logstash] logstash/async.go:280 Failed to publish events caused by: client is not connected
2021-07-05T13:36:00.096+1200 INFO [publisher] pipeline/retry.go:219 retryer: send unwait signal to consumer
2021-07-05T13:36:00.097+1200 INFO [publisher] pipeline/retry.go:223 done
filebeat.yml
output.logstash:
hosts: ["route-to-container:443"]
loadbalance: true
ssl.enabled: false
logstash.yml
http.host: "0.0.0.0"
log.level: info
logstash.conf (pipeline)
beats {
port => 5001
#client_inactivity_timeout => 3600 # 1 hour
stdout {
codec => json
Logstash does not show any errors in the container logs, or any logs that would suggest something is failing to connect
Connections are not being blocked by any firewalls
Kubernetes service is configured with
ports:
- name: beats
port: 5001
protocol: TCP
targetPort: 5001
route-to-container targets the beats port, and is secured via Edge
I have not been able to find any information on how to fix this so far, any help would be greatly appreciated
