Problems with AND in drop_events.when.or
I'm trying to drop a particular event id (4624 or 4627) when the TargetUserName is SYSTEM and then also just always drop event id 5379. What am I doing wrong here?
# Needed for Graylog
fields_under_root: true
fields.collector_node_id: ${sidecar.nodeName}
fields.gl2_source_collector: ${sidecar.nodeId}
output.logstash:
  hosts: ["HOST"]
path:
  data: C:\Program Files\Graylog\sidecar\cache\winlogbeat\data
  logs: C:\Program Files\Graylog\sidecar\logs
tags:
- windows
winlogbeat:
event_logs:
  - name: Application
  - name: System
  - name: Security
processors:
- drop_event.when.or:
  - equals.event_id: 5379
  - and:
    - equals.winlogbeat_event_data_TargetUserName: SYSTEM
    - or:
      - equals.event_id: 4624
      - equals.event_id: 4627
That field name looks wrong. It should be winlog.event_data.TargetUserName.
Good catch!
I'm breaking it down to be more simple and I'm still having problems with SYSTEM TargetUserName coming through with just:
processors:
  - and:
    - equals.winlogbeat_event_data.TargetUserName: SYSTEM
but this works just fine:
processors:
Any idea?
