Problems with values from paths other than the specified path
hello.
I wanted to analyze log informatins in real time by receiving them from the Wi-Fi terminal. so I used rsyslog to get logs and saved them as /var/log/remote.log.
filebeat.yml
filebeat.inputs:
  • type: log
    enabled: true
    paths:
    • /var/log/remote.log
      output.logstash:
      hosts: ["localhost:5043"]
logstash.conf
beats {
port => "5043"
It is working. however there are two problems.
  1. The value does not come in real time.
  2. I set the path to /var/log/remote.log but the /var/log/syslog, /var/log/syslog3, /var/log/syslog4 logs are also included.
What should i do?
Are you parsing the date of the events, if you don't parse the date of the original event it will use a default date and events will appear to be created in batch instead of real time.
Do you have any module enabled by default?
