I have set up an ELK server along with a Client Server that are working fine. I configured the client to send Syslogs to Logstash and can visualize it on Kibana and it works fine.
I'm not done yet! I decided to include a Juniper SRX210 router to see if I could send Syslogs and J-Flow to Logstash/ELK Server as well and visualize them with Kibana just like I do with the logs from my Client Server.
How would this be done? I configured my router for J-Flow version 9 by following the following guide; http://kb.juniper.net/InfoCenter/index?page=content&id=kb16677&actp=search
So, it should be sending it's flow to port 2222 if I'm correct, but how would I be able to check that? I assume that I will need to edit Logstash's input config file so it accepts port's 2222 flow.
Anyone who can help me out with this one?
