Why is my Logstash using huge CPU and how to fix it?
I am using ELK GA 5.0.0 in my Linux box. I am using 2 logstash instances to pull from Kafka, and it is having high CPU utilization. I tried /_node/hot_threads?human=true and below are the results;
node 1
Hot threads at 2017-05-15T06:25:27+00:00, busiestThreads=3:
83.03 % of cpu usage, state: runnable, thread name: 'Ruby-0-Thread-13'
/apps/ELK/Logstash/vendor/bundle/jruby/1.9/gems/logstash-input-kafka-5.0.5/lib/logstash/inputs/kafka.rb:191
	java.lang.System.identityHashCode(Native Method)
	org.jruby.javasupport.util.ObjectProxyCache.hash(ObjectProxyCache.java:174)
	org.jruby.javasupport.util.ObjectProxyCache.getOrCreate(ObjectProxyCache.java:163)
	org.jruby.javasupport.Java.getInstance(Java.java:385)
	org.jruby.javasupport.Java.getInstance(Java.java:364)
	org.jruby.javasupport.JavaUtil.convertJavaToUsableRubyObject(JavaUtil.java:194)
	org.jruby.javasupport.JavaMethod.convertReturn(JavaMethod.java:513)
	org.jruby.javasupport.JavaMethod.invokeDirectWithExceptionHandling(JavaMethod.java:437)
	org.jruby.javasupport.JavaMethod.invokeDirect(JavaMethod.java:300)
	org.jruby.java.invokers.InstanceMethodInvoker.call(InstanceMethodInvoker.java:35)
82.94 % of cpu usage, state: runnable, thread name: 'Ruby-0-Thread-11'
	sun.nio.ch.EPollArrayWrapper.epollWait(Native Method)
	sun.nio.ch.EPollArrayWrapper.poll(EPollArrayWrapper.java:269)
	sun.nio.ch.EPollSelectorImpl.doSelect(EPollSelectorImpl.java:93)
	sun.nio.ch.SelectorImpl.lockAndDoSelect(SelectorImpl.java:86)
	sun.nio.ch.SelectorImpl.selectNow(SelectorImpl.java:105)
	org.apache.kafka.common.network.Selector.select(Selector.java:452)
	org.apache.kafka.common.network.Selector.poll(Selector.java:277)
	org.apache.kafka.clients.NetworkClient.poll(NetworkClient.java:260)
	org.apache.kafka.clients.consumer.internals.ConsumerNetworkClient.clientPoll(ConsumerNetworkClient.java:360)
	org.apache.kafka.clients.consumer.internals.ConsumerNetworkClient.poll(ConsumerNetworkClient.java:224)
82.87 % of cpu usage, state: runnable, thread name: 'Ruby-0-Thread-12'
node 2
Hot threads at 2017-05-15T06:24:45+00:00, busiestThreads=3:
94.48 % of cpu usage, state: runnable, thread name: 'Ruby-0-Thread-8'
0.5 % of cpu usage, state: waiting, thread name: '[main]>worker3'
	sun.misc.Unsafe.park(Native Method)
	java.util.concurrent.locks.LockSupport.park(LockSupport.java:175)
	java.util.concurrent.locks.AbstractQueuedSynchronizer.parkAndCheckInterrupt(AbstractQueuedSynchronizer.java:836)
	java.util.concurrent.locks.AbstractQueuedSynchronizer.doAcquireInterruptibly(AbstractQueuedSynchronizer.java:897)
	java.util.concurrent.locks.AbstractQueuedSynchronizer.acquireInterruptibly(AbstractQueuedSynchronizer.java:1222)
	java.util.concurrent.locks.ReentrantLock.lockInterruptibly(ReentrantLock.java:335)
	org.jruby.RubyThread.lockInterruptibly(RubyThread.java:1470)
	org.jruby.ext.thread.Mutex.lock(Mutex.java:91)
	org.jruby.ext.thread.Mutex.synchronize(Mutex.java:147)
	org.jruby.ext.thread.Mutex$INVOKER$i$0$0$synchronize.call(Mutex$INVOKER$i$0$0$synchronize.gen)
0.5 % of cpu usage, state: waiting, thread name: '[main]>worker4'
Somebody kindly tell me why is this happening and how to fix this? Thanks in advance.
I only run one instance of logstash on my computer and it uses only a few percent of my CPU indeed. This high CPU usage might indicate that your config is somewhere wrong (at least, that's the case for me).
Do you have any output when you use rubydebug output codec?
Hi, below are my logstash configurations;
logstash 1
	kafka{
		group_id => "mygroup1"
		topics => ["mytopic1"]
		bootstrap_servers => "192.168.1.10:9091,192.168.1.11:9093,192.168.1.12:9092"
		codec => json
	if[fields][logtype] == "loga"{
		grok{
			match => { "message" => "%{NUMBER:data1}\s*%{NUMBER:data2}\s*%{NUMBER:data3}\s*%{NUMBER:data4}\s*%{NUMBER:data5}\s*%{NUMBER:data6}\s*%{NUMBER:data7}\s*%{NUMBER:data8}\s*%{NUMBER:data9}\s*%{NUMBER:data10}\s*%{NUMBER:data11}\s*%{NUMBER:data12}\s*%{NUMBER:data13}\s*%{NUMBER:data14}\s*%{NUMBER:data15}\s*%{NUMBER:data16}\s*%{NUMBER:data17}\t (?<timestamp>20%{YEAR}-%{MONTHNUM}-%{MONTHDAY} %{HOUR}:?%{MINUTE}(?::?%{SECOND}))" }
		date{
			match => [ "timestamp", "YYYY-MM-dd HH:mm:ss" ]
			target => "@timestamp"
	}else{
		grok {
			match => { "message" => "<(?<timestamp>%{MONTH} %{MONTHDAY}, 20%{YEAR} %{HOUR}:?%{MINUTE}(?::?%{SECOND}) (?:AM|PM))\> <%{GREEDYDATA:data1}> <%{GREEDYDATA:data2}> <%{GREEDYDATA:data3}> <%{GREEDYDATA:data4}> <%{GREEDYDATA:data5}> <%{GREEDYDATA:data6}> <%{GREEDYDATA:data7}>\n <%{GREEDYDATA:text1}>" }
		date {
			match => [ "timestamp", "MMM dd, YYYY hh:mm:ss:SSS aa" ]
			timezone => "UTC"
output{
	if "unwanted_log" not in [tags]{
				hosts => ["192.168.1.100:9200","192.168.1.101:9200","192.168.1.102:9200"]
				index => "loga-%{+YYYY-MM-dd}"
				user => elastic
				password => "El%405tic"
		}else{
				user => elastic
				index => "logb-%{+YYYY-MM-dd}"
logstash 2
	kafka{
		group_id => "group2"
		topics => ["mytopic2"]
		codec => json
		add_field => { "logtype" => "LOGFILE" }
	kafka{
        codec => json
		group_id => "group3"
		topics => ["mytopic3"]
	kafka{
		group_id => "group4"
        topics => ["mytopic4"]
		add_field => { "logtype" => "LOGFILE2" }
	if[logtype] == "LOGFILE"{
		if[fields][logtype] == "LOGFILE1A"{
			grok{
				match => { "message" => "####<(?<timestamp>%{MONTH} %{MONTHDAY}, 20%{YEAR} %{HOUR}:?%{MINUTE}(?::?%{SECOND}) (?:AM|PM) (?:GMT))\> <%{GREEDYDATA:data1}> <%{GREEDYDATA:data2}> <%{GREEDYDATA}> <%{GREEDYDATA:data3}> <%{GREEDYDATA}> <%{GREEDYDATA}> <%{GREEDYDATA}> <%{GREEDYDATA:data4}> <%{GREEDYDATA}> <%{GREEDYDATA}> <%{GREEDYDATA:data5}>" }
			date {
				match => [ "timestamp", "MMM dd, YYYY hh:mm:ss aa z" ]
				timezone => "GMT"
		}else if[fields][logtype] == "LOGFILE1B"{
			grok{
				match => { "message" => "%{NOTSPACE:data1} %{NOTSPACE:data2} ('%{NOTSPACE:data3}'|%{NOTSPACE:data3}) %{NOTSPACE:data4} %{NOTSPACE:data5} %{NOTSPACE:data6} %{NOTSPACE:data7} %{NOTSPACE:data8} %{NOTSPACE:data9} %{NOTSPACE:data10} ('%{NOTSPACE:data11}'|%{NOTSPACE:data11}) %{NOTSPACE:data12} ('%{GREEDYDATA:data13}'|%{NOTSPACE:data13}) ('%{GREEDYDATA:data14}'|%{NOTSPACE:data14}) ('%{GREEDYDATA:data15}'|%{NOTSPACE:data15}) ('%{GREEDYDATA:data16}'|%{NOTSPACE:data16})" }
			if [data9] == "/home/index" {
				mutate {
					add_tag => [ "unwanted_entry"]
			}else{
				if [data4] == "-" {
					mutate {
						replace => [ "data4", "-1" ]
				if [data6] == "-" {
					mutate {
						replace => [ "data6", "-1" ]
				mutate {
					add_field => {
						"dateTime" => "%{data1} %{data2}"
					remove_field => [ "data1", "data2" ]
					gsub => ["data7","\'",""]
				date {
					match => [ "dateTime", "YYYY-MM-dd HH:mm:ss" ]
					timezone => "GMT"
	}else if[logtype] == "LOGFILE2"{
		grok {
			match => { "message" => "^##(?<level>(LV1|LV2|LV3)) (?<timestamp>%{MONTHDAY}-%{MONTH}-%{YEAR} %{TIME}) %{NOTSPACE:data1} %{NOTSPACE:data2} %{GREEDYDATA:data3}" }
	    date {
			match => [ "timestamp", "dd-MMM-yyyy HH:mm:ss.SSS" ]
			timezone => "UTC"
output{
	if "unwanted_entry" not in [tags]{
					user => elastic
					user => elastic
				index => "logc-%{+YYYY-MM-dd}"
				user => elastic
in output section, add:
stdout {
  codec => rubydebug
Launch logstash in command line (or configure log output) and see if there is any error
Hi, is the same possible with file output, so that I can analyze it better, like;
 file {
   path => rubydebug.log
   codec => rubydebug
Probably
