Winlogbeat - Need Help with Drop_fields
So basically what i would like to do is drop everything from the fields and manually include a few.
So to say, i want to drop every field that im not putting/specifying in this config file.
In this case i tried to specifiy and tie it to 4624 and 4625 event id.
But also my second problem is that "drop_fields" doesnt seem to work at all. Even when i try to drop only a specific field.
- name: Security
    event_id: 4624, 4625
    ignore_older:
    processors:
      - drop_event.when.or:
        - and:
          - equals.winlog.event_id: 4624
          - or:
            # Exclude these conditions from Event ID 4624
            - equals.winlog.event_data.TargetUserName": 'SYSTEM'
            - equals.winlog.event_data.SubjectUserSid: 'S-1-0-0'
        - and:
          - equals.winlog.event_id: 4625
          - or:
            # Exclude these conditions from Event ID 4625
            - equals.winlog.event_data.TargetUserSid: 'S-1-5-18'
            - equals.winlog.event_data.TargetUserName: 'SYSTEM'
      - drop_fields:
          fields: ["winlog.channel", "winlog.event_data.IpAddress", "winlog.event_data.IpPort", "winlog.event_data.LogonProcessName", "winlog.event_data.ProcessName", "winlog.event_data.SubjectDomainName", "winlog.event_data.TargetUserName", "winlog.event_data.TargetUserSid"]
          when.not.or:
I think you need to quote the numbers to make them a string. And I would add ignore_missing: true to the drop_fields.
processors:
  - and:
    - equals.winlog.event_id: '4624'
    - or:
      - equals.winlog.event_data.TargetUserName: SYSTEM
      - equals.winlog.event_data.SubjectUserSid: S-1-0-0
  - and:
    - equals.winlog.event_id: '4625'
    - or:
      - equals.winlog.event_data.TargetUserSid: S-1-5-18
- drop_fields:
    fields:
    - winlog.channel
    - winlog.event_data.IpAddress
    - winlog.event_data.IpPort
    - winlog.event_data.LogonProcessName
    - winlog.event_data.ProcessName
    - winlog.event_data.SubjectDomainName
    - winlog.event_data.TargetUserName
    - winlog.event_data.TargetUserSid
    when.not.or:
It doesn't seems to take effect. I still see the old fields appearing in Kibana.
Also i noticed at the end.
    when.not.or:
So here we basically exclude event 4624 and 4625. Problem is here that i actually want specify what fields i keep in 4624 and 4625.
Also, when i run this here, its only dropping these specific fields. I would like to keep, so if its not matching with these drop the other fields, if it matches i want to keep them
- drop_fields:
    fields:
    - winlog.channel
Can i do something that specifies 4624 and 4625 where i can include fields manually and drop all the others?
I really would like to drop every "winlog" field and then specify which i want to keep. Its not an option for me to exclude field one by one.
I think i solved my problem. With this everything else drops but the specified fields not.
It was easier to use the following:
    processors:
      - include_fields:
So i tie this to the type of the log source for example 'System' or 'Security':
- name: System
    ignore_older:
    event_id: 7036
    processors:
      - include_fields:
          fields: ["winlog.event_id", "winlog.channel", "winlog.event_data.param1", "winlog.event_data.param2"]
- name: Security
    ignore_older:
    event_id: 2
    processors:
      - include_fields:
