Hi team and thank you for your work.
I am very new to ES and I am trying to build a simple stack with 1 ES, 1 KB and 2 filebeats (launched with binaries) all v7.5. I am not using LogStash but the prepacked modules of Filebeat.
Things were going well before new year but as I come back to the office, I notice some new documents are indexed for the end of the year of 2020.
After investigation, I can see that only System events are concerned. In fact, any event in the rotated log files (for example I have /var/log/messages-20191229) that has not been indexed, is now indexed as in 2020.
As an example I have in this file:
Dec 22 04:34:59 my-system kernel: Firewall: *UDP_IN Blocked* IN=eth0 OUT= MAC=xx:...:xx SRC=xxx.xxx.xxx.xxx DST=xxx.xxx.xxx.xxx LEN=1100 TOS=0x00 PREC=0x00 TTL=42 ID=54955 DF PROTO=UDP SPT=60569 DPT=443 LEN=1080
and in Kibana:
"_index": "filebeat-7.5.1-2020.01.06-000001",
"_type": "_doc",
"_id": "ceeSgG8BDy804je_mJfq",
"_version": 1,
"_score": null,
"_source": {
"agent": {
"hostname": "my-system.tld",
"name": "my-system",
"id": "d77c284b-dfd8-4d26-ab82-1fad8bc6ce6f",
"type": "filebeat",
"ephemeral_id": "0f8e7686-b861-4b60-8855-5b4ddcd6c5f6",
"version": "7.5.1"
"process": {
"name": "kernel"
"log": {
"file": {
"path": "/var/log/messages-20191229"
"offset": 1499167
"fileset": {
"name": "syslog"
"message": "Firewall: *UDP_IN Blocked* IN=eth0 OUT= MAC=xx:...:xx SRC=xxx.xxx.xxx.xxx DST=xxx.xxx.xxx.xxx LEN=1100 TOS=0x00 PREC=0x00 TTL=42 ID=54955 DF PROTO=UDP SPT=60569 DPT=443 LEN=1080 ",
"input": {
"type": "log"
"@timestamp": "2020-12-22T04:34:59.000-05:00",
"system": {
"syslog": {}
"ecs": {
"version": "1.1.0"
"service": {
"type": "system"
"host": {
"hostname": "my-system",
"os": {
"kernel": "3.10.0-962.3.2.lve1.5.26.7.el7.x86_64",
"name": "CloudLinux",
"family": "",
"version": "7.7 (Valery Bykovsky)",
"platform": "cloudlinux"
"containerized": false,
"id": "a195f221b91edcc1ff7319c05c12b888",
"architecture": "x86_64"
"event": {
"timezone": "-05:00",
"module": "system",
"dataset": "system.syslog"
"fields": {
"suricata.eve.timestamp": [
"2020-12-22T09:34:59.000Z"
"@timestamp": [
"sort": [
1608629699000
I made some tests and reload the content of any rotated log file before 2020 by doing:
- delete documents with timestamp greater than today in ES
- delete any pipeline
- set file offset to 0 in
data/registry/filebeat/data.jsonfor appropriate files
...but still, all of these files' content (messages-201912* and secure-201912*) is indexed as end of year 2020.
In short, as long as I indexed their content in 2019 everything was going well, but now we are in 2020 I can't index them without having wrong timestamp.
Please forgive my poor english
Any help appreciated.
Thomas
