A few questions: Index per "tenant" sharing schemas, dates auto-detected?
I'd like to make a search system such that each "user" of the system
has their own set of indexes, but all the user share a common set of
schemas and field settings.
If I put something in /_all/tweet/_mapping will it affect all existing
and future automatically-created indexes such as /foo/tweet/ and /bar/
tweet/?
Or, do I have to configure the indexes each time a new user is added,
and then reconfigure all existing users when a schema is updated?
I notice that the docs say that types can be automatically detected
like numbers, strings. The example (in
http://www.elasticsearch.com/docs/elasticsearch/rest_api/index/) also
includes a date, are those detected automatically as well?
There was actually a thread similar to this which resulted in this
issue: Boot-time Mapping Definitions · Issue #86 · elastic/elasticsearch · GitHub. This means
you can define mappings in advance, and they will automatically be applied
to all indices created.
tweet/?
Thats another option that was discussed, there is an issue for this, and I
plan to support this notion as well.
Dates (strings) are automatically detected using the following logic: They
much have either '-' or ':' in the string, and the date parser manages to
parse them. If both happen, then they are treated as dates. Note, there was
a problem with this in 0.5.1, and its fixed in master (upcoming 0.6.0).
-shay.banon
For the fix for issue #86, if I update the mapping file(s), would it
update the mappings for indexes that already exist?
And was that fix included in the last release?
On Apr 2, 2:42 am, Shay Banon shay.ba...@elasticsearch.com wrote:
issue:Boot-time Mapping Definitions · Issue #86 · elastic/elasticsearch · GitHub. This means
tweet/?
-shay.banon
No, when you update the mappings, it will only be applied to new indices
created.
Not in 0.5.1. It is in master and will be included in 0.6.0 which I hope to
release in the coming days.
means
applied
tweet/?
I
They
was
-shay.banon
