AuditLog index filtering problem
Hi. We are using the ElasticStack v 6.5.3 .
Our requirements are to only record audit events originating from 2x index patterns exclusively:
  • aaa-*
  • bbb-*
Here is a fragment of our configuration in elasticsearch.yml
xpack.security.audit.enabled: true
xpack.security.audit.outputs: [ logfile ]
xpack.security.audit.logfile.events.ignore_filters.name.realms: ["reserved", "__anonymous", "__attach"]
xpack.security.audit.logfile.events.ignore_filters.name.indices: ["~(aaa|bbb)-*"]
xpack.security.audit.logfile.events.ignore_filters.name.users: ["beat"]
xpack.security.audit.logfile.events.emit_request_body: false
  • We have tried to achieve our goal by creating a lucene regexp with a negation but this seems to be ignored. Can you point us to a correct solution?
  • Will it be possible to include the request body, assuming the per-index filtering is active?
Hi @mmisztal1980 ,
  • You need to contain the regexp in /
  • You are missing a . because * will match the preceding shortest pattern zero-or-more times and you need to tell it what is the preceding shortest pattern it needs to match ( in your case any character i.e. .
xpack.security.audit.logfile.events.ignore_filters.name.indices: ["/~(aaa|bbb)-.*/"]
