Hi Everyone,
I aim to ingest datas in ES documents.
My datas are pretty much like this ::
fixed_field1;fixed_field2;...;variable_field1;variable_field2;...
And then, I want to build ES documents like this ::
"fixed_field1_label":"fixed_field1",
"fixed_field2_label":"fixed_field2",
"variable_field1_label":"variable_field1",
"variable_field2_label":"variable_field2",
The fixed part is very very common whereas the variable part is very unique.
I was wondering, in order to save space storage, if there was an approach to externalize the fixed part ? I saw things such as "nested" or "has_child" or "has_parent", but I fear that this make impossible querying throught Kibana or Grafana. Indeed, my documents must be readable by those kind of tools...
Thanks for your help
