Best way to prevent add_fields with %{} when field does not exist
I have a lot of csv fields that i'm using a csv filter to parse and sometimes the fields are blank. Right after parsing them, I assign the results to new fields using mutate's add_field. Here is a sample
csv {
separator => "," columns => [ "pid", "name", "dev_contact", "dev_location", "dev_vendor", "dev_family"]
mutate {
add_field => {
"id" => "%{pid}"
"name" => "%{name}"
"[dev][contact]" => "%{dev_contact}"
"[dev][location]" => "%{dev_location}"
"[dev][vendor]" => "%{dev_vendor}"
"[dev][family]" => "%{dev_family}"
Using this method, if there is no entry for any field, such as dev_contact, then my [dev][contact] will contain
%{dev_contact}.
I'm aware that I can check if dev_contact exists before assignment like this:
if [dev_contact]{
mutate {
add_field => { "[dev][contact]" => "%{dev_contact}" }
but i really do not want to do that for all of my fields since my actual csv has hundreds of fields. Is there a better way to prevent add_field from putting the variable in if nothing exists?
Thanks for any ideas!
No, but you could e.g.
  • write a snippet of ruby in a ruby filter to do all the necessary mutations or
  • generate the necessary configuration so it doesn't matter if you have hundreds of conditionals.
Thanks, Magnus. I just wanted to verify that I wasn't making things harder than they should be.
