Compare two values in a single field of same index
Hi All,
I am new to Kibana and wanted to check last 4 hours difference between two values which are in in a single field of same index.
Below is a small example
My Index have 5 fields ( datetime, state, errorcode, filename, os_type)
In state field i have 4 different values( picked, notpicked, completed, inprogress)
My requirement is : In last 4 hour i need to check state fields with picked & completed are how many with counts.
Please help me in sorting out this
you can achieve this in few different ways:
  • you can create a horizontal bar visualization with a term bucket aggregation and you can add than a filter on the visualization specifying only picked and completed
  • similar to the horizontal bar you can have a data table with the same results if you prefer showing just the numbers
If you want the sum of the count of picket and completed, just disable the bucketing and keep the filter on.
