Hi all
We are struggling how to configure our index behavior between 3 phases it needs to cope with bravely (number of nodes,number of shards,merging segments, sorting the index, and size limitations and any other parameters that may help us
Our app consists with 3 main phases for elastic usages:
1.initial massive insert :
- 2.5 Billion docs / 10 days (3000 docs / sec)
- the docs have Parent-Child relations ( avg of 1.4 children per parent)
- the children contains nested fields, which may vary from 1 to 1M short-text values per nested field (e.g. nested document)
- avg doc size (including the nested docs from the nested fields) is 1kb
- massive(ish) update :
- 15% of the documents (children) are updated (by inserting nested fields values - e.g. some more nested docs , but small and homogeneous ones )
- these updates are based on several (limited) aggregation queries
- user free queries:
- each query the user requests produces ~15 additional aggregation queries on the results (this sucks , we know)
step 1-3 happens every x-days (never starting before step 2 is completed) , though expected data is much smaller (max ~10% of the initial number of documents - e.g. max 250M)
So... basically we are looking for a night in shiny armor to come and rescue us,
and if not,
than at least some good references , because the web lacks of documentations about how to cope with different index's usage phases.
Milkana and Nirit
