Hello ,
i am running Elasticsearch on a website called Cloud IDE gitpod. Once i start the docker image on the gitpod,
docker run \
--name elasticsearch \
--net elastic \
-p 9200:9200 \
-e discovery.type=single-node \
-e ES_JAVA_OPTS="-Xms1g -Xmx1g"\
-e xpack.security.enabled=false \
-it \
docker.elastic.co/elasticsearch/elasticsearch:8.2.2
Elasticsearch will start successfully i get a full https public url to access the service.. No PORT will be given in the end:
When i access the url in browser, i am able to see Elasticsearch details :
"name" : "3f0f5479c2cb",
"cluster_name" : "docker-cluster",
"cluster_uuid" : "5P-U6anjQUuIEqrn6IzRvA",
"version" : {
"number" : "8.2.3",
"build_flavor" : "default",
"build_type" : "docker",
"build_hash" : "9905bfb62a3f0b044948376b4f607f70a8a151b4",
"build_date" : "2022-06-08T22:21:36.455508792Z",
"build_snapshot" : false,
"lucene_version" : "9.1.0",
"minimum_wire_compatibility_version" : "7.17.0",
"minimum_index_compatibility_version" : "7.0.0"
When using logstash, i am not able to connect to https://9200-xxxx.gitpod.io/
elasticsearch{
hosts => "https://9200-xxxx.gitpod.io/"
index => "library-mgmt-system-logstasssh-index"
ecs_compatibility => disabled
It fails with Attempted to resurrect connection to dead ES instance, but got an error {:url=>"https://9200-xxxx.gitpod.io:9200/", :exception=>LogStash::Outputs::Elasticsearch::HttpClient::Pool::HostUnreachableError, :message=>"Elasticsearch Unreachable: [https://9200-xxxx.gitpod.io:9200/][Manticore::ConnectTimeout]
Not sure why logstash is looking for https://9200-xxxx.gitpod.io:9200
But instead it should just connect to
where Elasticsearch is running.
https://9200-xxxx.gitpod.io:9200 does not resolve on gitpod. As we cannot use ports . It gives directly https url internally port forward will be done.
