Connecting to port 9300 running inside a Docker container
I think I have the same issue as here:
But I am not sure how to implement the fix.
Elastic (5.4.3) running in Docker, started with docker-compose.
The relevant part of the docker-compose is:
my-elastic:
    image: docker.elastic.co/elasticsearch/elasticsearch:5.4.3
    container_name: my-elastic
    environment:
        - cluster.name=elasticsearch
        - xpack.security.enabled=false
        - discovery.type=single-node
        - bootstrap.memory_lock=true
        - "ES_JAVA_OPTS=-Xms1024m -Xmx3g"
    ulimits:
        memlock:
            soft: -1
            hard: -1
    mem_limit: 4g
    volumes:
        - ../../data/elasticsearch/data:/usr/share/elasticsearch/data
    ports:
        - 9200:9200
        - 9300:9300
When running a Java container as part of the docker-compose, it has no problem connecting to the elastic cluster (using port 9300 - an older connector; disclaimer: I didn't write the app, but I have to fix it).
However, when trying to run the java container on the host:
Adding transport node: localhost:9300
org.elasticsearch.client.transport.NoNodeAvailableException: None of the configured nodes are available: [{#transport#-1}{MyNFks6oRdCFAS0LRj3rRQ}{localhost}{127.0.0.1:9300}]
I tried adding
        - network.bind_host=0.0.0.0
to the environment, but it didn't help.
Any help would be greatly appreciated.
Thanks.
How do you build the TransportClient?
public static Client createTransportClient(String clusterNodes, String clusterName) throws Exception {
    logger.info("Creating Elasticsearch transport client");
    Settings settings = Settings.builder().put("cluster.name", clusterName).put("client.transport.sniff", true).build();
    TransportClient client = new PreBuiltTransportClient(settings);
    if (StringUtils.isNotEmpty(clusterNodes)) {
        for (String clusterNode : StringUtils.split(clusterNodes, ',')) {
            String hostName = StringUtils.substringBeforeLast(clusterNode, ":");
            String port = StringUtils.substringAfterLast(clusterNode, ":");
            Assert.hasText(hostName, "[Assertion failed] missing host name in 'clusterNodes'");
            Assert.hasText(port, "[Assertion failed] missing port in 'clusterNodes'");
            logger.info("Adding transport node: " + clusterNode);
            client.addTransportAddress(new InetSocketTransportAddress(InetAddress.getByName(hostName), Integer.valueOf(port)));
        client.connectedNodes();
    logger.info(client.admin().cluster().prepareHealth().get().toString());
    return client;
Disclaimer: this is not my code and I am rather new to Elasticsearch, so I don't know if this code is good or bad.
Thanks for your help.
What is the value for clusterName?
elasticsearch
Hi @dadoonet,
the clusterName is elasticsearch.
Is there any hope for me to fix this please ?
Thank you.
It looks good. May be a firewall issue with port 9300 which is actually blocked?
Could you share the logs of your elasticsearch instance?
Seems like the issue is caused by client.transport.sniff set to true.
//                                    .put("client.transport.sniff", true)
                        .build();
I have commented out that line and now it works.
However, I would still like to understand why.
It seems that a lot of people complained about not being able to connect to Docker containers and also there are lots of issues with the client.transport.sniff.
But despite reading a whole bunch of issues and replies and such, I still couldn't find an explanation. Which part of what client.transport.sniff does causes the issue ?
Regardless of whether you can answer this question, thank you for your help.
I honestly don't know.
But anyway, you should not use this TransportClient anymore. It's removed in the next major version.
