Connection issues between Elastic Agent (Filebeat) and Logstash: connection reset by peer
Hello everyone,
I am currently facing an issue where I keep encountering errors in the connection between the Elastic Agents (Filebeat) and Logstash.
There are always two related errors, and the target is always Logstash on port 5044 (Beats Input).
These errors occur with both Elastic Agent versions 8.14.x and 8.16.x, as well as with Logstash.
Error messages from the Elastic Agent:
failed to publish events: write tcp XX.XXX.XX.X:42550->XX.XXX.XX.X:5044: write: connection reset by peer
failed to publish events caused by: write tcp XX.XXX.XX.X:42550->XX.XXX.XX.X:5044: write: connection reset by peer
Initially, there were a lot of these messages, but they were significantly reduced using the following parameters. Unfortunately, the errors have not been eliminated entirely.
In the Logstash output of the Elastic Agent, the following was configured:
pipelining: 0
On the Beats Input in Elastic Agent, the timeout was increased:
client_inactivity_timeout => 1200
The log contains an entry referencing Beats v7, which results in a 404 error:
"log.origin.function": ["github.com/elastic/beats/v7/libbeat/outputs/logstash.(*syncClient).Publish"]
Does anyone have any idea where these errors might be coming from and how I can resolve them?
Thank you and best regards.
Here is the complete log entry:
"_index": ".ds-logs-elastic_agent.filebeat-XXXX-2024.12.04-000093",
"_id": "3wx2lpMBlD3uJqTDHxEd",
"_version": 1,
"_score": 0,
"_source": {
"agent": {
"name": "XXXXXXX",
"id": "a34f3d82-fe99-41c9-8480-5f3cc82a8ba6",
"ephemeral_id": "2e51f012-5f8b-44d8-859a-f195276548cf",
"type": "filebeat",
"version": "8.16.1"
"service.name": "filebeat",
"log": {
"file": {
"inode": "393721",
"path": "/opt/Elastic/Agent/data/elastic-agent-8.16.1-b6da7f/logs/elastic-agent-20241205.ndjson",
"device_id": "64768"
"offset": 6656134,
"source": "log-d0a517d9-9b23-4313-aae9-132d953e5716"
"elastic_agent": {
"version": "8.16.1",
"snapshot": false
"message": "Failed to publish events caused by: write tcp xx.xxx.xx.x:42550->xx.xxx.xx.x:5044: write: connection reset by peer",
"log.logger": "logstash",
"tags": ["beats_input_codec_plain_applied"],
"log.origin": {
"file.line": 162,
"function": "github.com/elastic/beats/v7/libbeat/outputs/logstash.(*syncClient).Publish",
"file.name": "logstash/sync.go"
"input": {
"type": "filestream"
"component": {
"binary": "filebeat",
"id": "log-d0a517d9-9b23-4313-aae9-132d953e5716",
"type": "log",
"dataset": "elastic_agent.filebeat"
"@timestamp": "2024-12-05T10:55:27.784Z",
"ecs": {
"version": "8.0.0"
"data_stream": {
"namespace": "XXXX",
"type": "logs",
"@version": "1",
"host": {
"hostname": "XXXXXXX",
"os": {
"kernel": "5.15.0-116-generic",
"codename": "jammy",
"name": "Ubuntu",
"type": "linux",
"family": "debian",
"version": "22.04.5 LTS (Jammy Jellyfish)",
"platform": "ubuntu"
"ip": ["xx.xxx.xx.x", "fe80::250:56ff:fe99:2ad7"],
"containerized": false,
"name": "XXXXXXX",
"id": "f383c09d524c4d0f9cad10d61490b4af",
"mac": ["00-50-56-99-2A-D7"],
"architecture": "x86_64"
"log.level": "error",
"event": {
"original": "Failed to publish events caused by: write tcp xx.xxx.xx.x:42550->xx.xxx.xx.x:5044: write: connection reset by peer",
"category": "other"
"fields": {
"elastic_agent.version": ["8.16.1"],
"component.binary": ["filebeat"],
"host.os.name.text": ["Ubuntu"],
"host.name.text": ["XXXXXXX"],
"host.hostname": ["XXXXXXX"],
"host.mac": ["00-50-56-99-2A-D7"],
"component.id": ["log-d0a517d9-9b23-4313-aae9-132d953e5716"],
"agent.name.text": ["XXXXXXX"],
"host.os.version": ["22.04.5 LTS (Jammy Jellyfish)"],
"host.os.name": ["Ubuntu"],
"log.level": ["error"],
"agent.name": ["XXXXXXX"],
"host.name": ["XXXXXXX"],
"event.original": ["Failed to publish events caused by: write tcp xx.xxx.xx.x:42550->xx.xxx.xx.x:5044: write: connection reset by peer"],
"host.os.type": ["linux"],
"input.type": ["filestream"],
"log.source": ["log-d0a517d9-9b23-4313-aae9-132d953e5716"],
"log.offset": [6656134],
"data_stream.type": ["logs"],
"host.architecture": ["x86_64"],
"log.origin.function": ["github.com/elastic/beats/v7/libbeat/outputs/logstash.(*syncClient).Publish"],
"agent.id": ["a34f3d82-fe99-41c9-8480-5f3cc82a8ba6"],
"ecs.version": ["8.0.0"],
"host.containerized": [false],
"service.name.text": ["filebeat"],
"agent.version": ["8.16.1"],
"host.os.family": ["debian"],
"log.origin.file.name.text": ["logstash/sync.go"],
"log.logger": ["logstash"],
"host.ip": ["xx.xxx.xx.x", "fe80::250:56ff:fe99:2ad7"],
"agent.type": ["filebeat"],
"host.os.kernel": ["5.15.0-116-generic"],
"component.dataset": ["elastic_agent.filebeat"],
"log.file.device_id": ["64768"],
"@version": ["1"],
"log.file.path.text": ["/opt/Elastic/Agent/data/elastic-agent-8.16.1-b6da7f/logs/elastic-agent-20241205.ndjson"],
"elastic_agent.snapshot": [false],
"host.id": ["f383c09d524c4d0f9cad10d61490b4af"],
"log.origin.file.line": [162],
"service.name": ["filebeat"],
"elastic_agent.id": ["a34f3d82-fe99-41c9-8480-5f3cc82a8ba6"],
"data_stream.namespace": ["XXXX"],
"host.os.codename": ["jammy"],
"message": ["Failed to publish events caused by: write tcp xx.xxx.xx.x:42550->xx.xxx.xx.x:5044: write: connection reset by peer"],
"component.type": ["log"],
"@timestamp": ["2024-12-05T10:55:27.784Z"],
"log.origin.file.name": ["logstash/sync.go"],
"host.os.platform": ["ubuntu"],
"log.file.inode": ["393721"],
"data_stream.dataset": ["elastic_agent.filebeat"],
"log.file.path": ["/opt/Elastic/Agent/data/elastic-agent-8.16.1-b6da7f/logs/elastic-agent-20241205.ndjson"],
"agent.ephemeral_id": ["2e51f012-5f8b-44d8-859a-f195276548cf"],
"category": ["other"],
"event.dataset": ["elastic_agent.filebeat"]
I most often see connection reset messages when there is a traffic inspecting firewall or proxy sitting between the Beat and its output destination.
Is there any sort of security device or firewall in play here?
Can you also share the message from the logstash side?
The nodes on which I get the error messages are in the same network segment, so there is no firewall or proxy in between.
Unfortunately I don't see anything on the Logstash, in which log should I get something?
Thanks for the help!
Depending on your environment Logstash may be writing to a log file or logging to console. You may need to increase the log level for Logstash itself.
Some info on Logstash logging here Logging | Logstash Reference [8.16] | Elastic
The log from the beat implies that Logstash is sending a reset on the connection while the beat is still writing data.
I would expect this to be visible as an error in the Logstash log. I assume you've checked the resources on your Logstash server and it has enough CPU, disk, and memory? Do you know how many agents you might have writing to logstash? Can you share your Logstash config and pipeline config as well?
you can also use tcpdump to capture the traffic on both ends, and wait for the connection reset, and see what the packet capture shows.
