We are using 3 data nodes, 3 master nodes, 2 client nodes as elastic cluster in Azure. We have an NGINX sitting in front of client nodes to proxy the data.
ES version: 2.2
NEST: 2.1.0
I am trying to connect from .NET application using NEST library and run simple GET query to retrieve a document using Id. Every now and then, the ES queries fails with the System.Net.Sockets.SocketException with error message: "A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond XX.XX.XX.XX:9200.".
I tried with following scenario as well.
- Remove NGINX from the path and directly connect to Client nodes. Only Azure Load Balancer in front of client nodes. - Same problem.
- Use native
HttpClientinstead of usingNESTlibrary - same problem. - Tweak connection settings on Elastic Client - same problem.
Currently, I am using Static Connection pool following connection settings.
var staticPool = new StaticConnectionPool(new[] {new Uri("http://es-url:9200")});
var connection = new HttpConnection();
var settings = new ConnectionSettings(staticPool, connection);
settings = settings.EnableTcpKeepAlive(TimeSpan.FromMilliseconds(2000)
.TimeSpan.FromMilliseconds(2000))
.RequestTimeout(TimeSpan.FromMinutes(10))
.MaximumRetries(10)
.DisableAutomaticProxyDetection()
.DisableDirectStreaming()
.MaxRetryTimeout(TimeSpan.FromMinutes(10))
.EnableHttpCompression()
.DisablePing();
Any suggestions? This is a blocking issue on our side as connection attempt to ES fails with above mentioned exception at constant rate and we would like to solve this problem as soon as possible.
Tejas
