Hello All,
I am completely confused in managing and connection elasticsearch. Thanks a
lot to help me solve my problem.
-I started to create some Index inside ElasticSearch but even when I delete
them they return! I found that it is because they are still available in
other nodes! Thanks to let me know how i can delete the completely?
-Also I have to open two nodes to be able to work with ElasticSearch
otherwise I encounter with 'no known master node '!
-When I had a problem and I close a node, nothing will work till I restart
my computer!
-Also all my index status are red!
I just explain the status to inform you about the condition. Thank you to
help me to get rid of this dilemma!
Just please consider that I am new user of Elasticsearch and apologize for
such question!
[2015-02-18 12:44:59,846][INFO ][node                     ] [Helleyes]
version[1.4.2], pid[483], build[927caff/2014-12-16T14:11:12Z]
[2015-02-18 12:44:59,847][INFO ][node                     ] [Helleyes]
initializing ...
[2015-02-18 12:44:59,861][INFO ][plugins                  ] [Helleyes]
loaded [marvel], sites [marvel]
[2015-02-18 12:45:02,745][INFO ][node                     ] [Helleyes]
initialized
[2015-02-18 12:45:02,746][INFO ][node                     ] [Helleyes]
starting ...
[2015-02-18 12:45:02,811][INFO ][transport                ] [Helleyes]
bound_address {inet[/0:0:0:0:0:0:0:0:9305]}, publish_address
{inet[/192.168.110.133:9305]}
[2015-02-18 12:45:02,827][INFO ][discovery                ] [Helleyes]
elasticsearch/boK22-mkRPGMo-1TSnXhZw
[2015-02-18 12:45:06,599][INFO ][cluster.service          ] [Helleyes]
new_master
[Helleyes][boK22-mkRPGMo-1TSnXhZw][webdev99s-Mac-mini.local][inet[/192.168.110.133:9305]],
reason: zen-disco-join (elected_as_master)
[2015-02-18 12:45:06,708][INFO ][http                     ] [Helleyes]
bound_address {inet[/0:0:0:0:0:0:0:0:9205]}, publish_address
{inet[/192.168.110.133:9205]}
[2015-02-18 12:45:06,709][INFO ][node                     ] [Helleyes]
started
[2015-02-18 12:45:07,594][INFO ][discovery.zen            ] [Helleyes]
updating discovery.zen.minimum_master_nodes from [-1] to [2]
[2015-02-18 12:45:07,710][INFO ][gateway                  ] [Helleyes]
recovered [23] indices into cluster_state
[2015-02-18 12:45:07,711][WARN ][discovery.zen            ] [Helleyes] not
enough master nodes on change of minimum_master_nodes from [-1] to [2],
current nodes:
{[Helleyes][boK22-mkRPGMo-1TSnXhZw][webdev99s-Mac-mini.local][inet[/192.168.110.133:9305]],}
[2015-02-18 12:45:07,719][ERROR][cluster.action.shard     ] [Helleyes]
unexpected failure during [shard-started ([logstash-2015.02.05][0],
node[boK22-mkRPGMo-1TSnXhZw], [P], s[INITIALIZING]), reason [after recovery
from gateway]]
org.elasticsearch.common.util.concurrent.EsRejectedExecutionException: no
longer master. source: [shard-started ([logstash-2015.02.05][0],
from gateway]]
at
org.elasticsearch.cluster.ClusterStateUpdateTask.onNoLongerMaster(ClusterStateUpdateTask.java:53)
at
org.elasticsearch.cluster.service.InternalClusterService$UpdateTask.run(InternalClusterService.java:324)
at
org.elasticsearch.common.util.concurrent.PrioritizedEsThreadPoolExecutor$TieBreakingPrioritizedRunnable.run(PrioritizedEsThreadPoolExecutor.java:153)
at
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
[2015-02-18 12:45:07,722][ERROR][cluster.action.shard     ] [Helleyes]
unexpected failure during [shard-started ([test3][2],
from gateway]]
longer master. source: [shard-started ([test3][2],
from gateway]]
at
at
at
at
at
[2015-02-18 12:45:08,302][WARN ][cluster.action.shard     ] [Helleyes]
can't send shard started for [.marvel-2015.02.13][0],
node[boK22-mkRPGMo-1TSnXhZw], [P], s[INITIALIZING]. no master known.
[2015-02-18 12:45:10,771][WARN ][cluster.action.shard     ] [Helleyes]
can't send shard started for [.marvel-2015.02.18][0],
[2015-02-18 12:45:12,808][DEBUG][action.admin.indices.template.get]
[Helleyes] no known master node, scheduling a retry
[2015-02-18 12:45:42,811][DEBUG][action.admin.indices.template.get]
[Helleyes] observer: timeout notification from cluster service. timeout
setting [30s], time since start [30s]
[2015-02-18 12:45:42,832][DEBUG][action.admin.indices.template.put]
[2015-02-18 12:46:12,833][DEBUG][action.admin.indices.template.put]
[2015-02-18 12:46:12,841][ERROR][marvel.agent.exporter    ] [Helleyes]
error adding the marvel template to [[0:0:0:0:0:0:0:0]:9205] response code
[503 Service Unavailable]. content:
[{"error":"MasterNotDiscoveredException[waited for [30s]]","status":503}]
[2015-02-18 12:46:12,842][ERROR][marvel.agent.exporter    ] [Helleyes]
failed to verify/upload the marvel template to [[0:0:0:0:0:0:0:0]:9205]:
Server returned HTTP response code: 503 for URL:
http://[0:0:0:0:0:0:0:0]:9205/_template/marvel
could not connect to any configured elasticsearch instances:
[2015-02-18 12:46:12,844][DEBUG][action.admin.indices.template.get]
[2015-02-18 12:46:42,845][DEBUG][action.admin.indices.template.get]
[2015-02-18 12:46:42,853][DEBUG][action.admin.indices.template.put]
[2015-02-18 12:47:12,854][DEBUG][action.admin.indices.template.put]
[2015-02-18 12:47:12,858][ERROR][marvel.agent.exporter    ] [Helleyes]
[2015-02-18 12:47:12,859][ERROR][marvel.agent.exporter    ] [Helleyes]
[2015-02-18 12:47:22,871][DEBUG][action.admin.indices.template.get]
[2015-02-18 12:47:52,872][DEBUG][action.admin.indices.template.get]
[2015-02-18 12:47:52,878][DEBUG][action.admin.indices.template.put]
[2015-02-18 12:48:22,879][DEBUG][action.admin.indices.template.put]
[2015-02-18 12:48:22,881][ERROR][marvel.agent.exporter    ] [Helleyes]
[2015-02-18 12:48:32,892][DEBUG][action.admin.indices.template.get]
[2015-02-18 12:49:02,893][DEBUG][action.admin.indices.template.get]
[2015-02-18 12:49:02,899][DEBUG][action.admin.indices.template.put]
[2015-02-18 12:49:32,900][DEBUG][action.admin.indices.template.put]
[2015-02-18 12:49:32,903][ERROR][marvel.agent.exporter    ] [Helleyes]
[2015-02-18 12:49:32,904][ERROR][marvel.agent.exporter    ] [Helleyes]
[2015-02-18 12:49:42,916][DEBUG][action.admin.indices.template.get]
[2015-02-18 12:50:12,918][DEBUG][action.admin.indices.template.get]
[2015-02-18 12:50:12,924][DEBUG][action.admin.indices.template.put]
[2015-02-18 12:50:42,925][DEBUG][action.admin.indices.template.put]
[2015-02-18 12:50:42,929][ERROR][marvel.agent.exporter    ] [Helleyes]
[2015-02-18 12:50:52,940][DEBUG][action.admin.indices.template.get]
[2015-02-18 12:51:22,941][DEBUG][action.admin.indices.template.get]
[2015-02-18 12:51:22,951][DEBUG][action.admin.indices.template.put]
[2015-02-18 12:51:52,952][DEBUG][action.admin.indices.template.put]
[2015-02-18 12:51:52,956][ERROR][marvel.agent.exporter    ] [Helleyes]
[2015-02-18 12:52:02,968][DEBUG][action.admin.indices.template.get]
[2015-02-18 12:52:32,969][DEBUG][action.admin.indices.template.get]
[2015-02-18 12:52:32,976][DEBUG][action.admin.indices.template.put]
[2015-02-18 12:53:02,976][DEBUG][action.admin.indices.template.put]
[2015-02-18 12:53:02,979][ERROR][marvel.agent.exporter    ] [Helleyes]
[2015-02-18 12:53:12,992][DEBUG][action.admin.indices.template.get]
[2015-02-18 12:53:42,993][DEBUG][action.admin.indices.template.get]
[2015-02-18 12:53:42,998][DEBUG][action.admin.indices.template.put]
[2015-02-18 12:54:13,000][DEBUG][action.admin.indices.template.put]
[2015-02-18 12:54:13,004][ERROR][marvel.agent.exporter    ] [Helleyes]
[2015-02-18 12:54:13,005][ERROR][marvel.agent.exporter    ] [Helleyes]
[2015-02-18 12:54:23,017][DEBUG][action.admin.indices.template.get]
[2015-02-18 12:54:53,018][DEBUG][action.admin.indices.template.get]
[2015-02-18 12:54:53,025][DEBUG][action.admin.indices.template.put]
[2015-02-18 12:55:23,026][DEBUG][action.admin.indices.template.put]
[2015-02-18 12:55:23,029][ERROR][marvel.agent.exporter    ] [Helleyes]
[2015-02-18 12:55:33,041][DEBUG][action.admin.indices.template.get]
Regards,
Ali
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/c51223bc-53c2-4d08-9c3e-c401ac8609bf%40googlegroups.com.
