Contact for solutions when index lifecycle policies are not reflected
I am using ECK 8.14 and here is the reflected Index Lifecycle Policies(ILM) content:
PUT _ilm/policy/ECK-ILM
  "policy": {
    "phases": {
      "hot": {
        "min_age": "0ms",
        "actions": {
          "set_priority": {
            "priority": 100
          "rollover": {
            "max_age": "7d",
            "max_docs": 7,
            "max_primary_shard_size": "30gb",
            "max_size": "5gb"
      "warm": {
        "min_age": "7d",
        "actions": {
          "set_priority": {
            "priority": 50
      "delete": {
        "min_age": "7d",
        "actions": {
          "delete": {
            "delete_searchable_snapshot": true
However, in reality, the above policy does not seem to be reflected.
I added the ILM policy, but it doesn't seem to be reflected. I'm writing this to get help on how to secure capacity as capacity is saturated. Please clear it manually or let me know if I missed something in the settings.
Hi @sjoh9163 Welcome to the community.
According to the image looks like the ILM is actually policy applied.
Click on this
And show the results it will show the backing indices for the data stream
BTW max_size is not recommended and is in conflict with the max_primary_shard_size
Thanks Mr. Brown.
It may be a crash issue as you said.
I changed ILM policy to the following:
  "policy": {
    "phases": {
      "hot": {
        "min_age": "0ms",
        "actions": {
          "set_priority": {
            "priority": 100
          "rollover": {
            "max_primary_shard_size": "5gb"
I hope this is the solution.
That is very small, especially for logs... should be between 30-50gb
and what happened to your warm and delete.
You should also look at this API to diagnose issues with ILM
If you still have issues, run that command on the index with the issues, and we can debug it
