Control flow (if statement) script not working
I have a java method that creates a new document if it does not already
exist otherwise sets a field in the doc to a value given a condition. This
is done in a bulk request.
bulkRequest.add(client.prepareUpdate("tests", "test", "myId")
.setFields("_source")
.setScript("ctx._source.counter > 0 ? 20")
.setUpsert(contentBuilder)
The above does not work.
However if I remove the conditional check and simply increment the counter
value it works (without changing anything else in the code).
.setScript("ctx._source.counter += 1")
Can someone please assist me as I do not know what I am doing wrong. I am
using ES 1.0.
Thank you.
Dirk
I am not sure if anyone can read this post as it says it has not been accepted by the mailing list.
But just an update - I managed to fix the issue by adding parentheses to the code:
.setScript("if (ctx._source.counter > 0) ctx._source.counter = 20")
Does not work.
.setScript("if (ctx._source.counter > 0) { ctx._source.counter = 20};")
Working.
