CRLF injection issue (Improper Output Neutralization for Logs) /src/lib/connectors/xhr.js 76
Hi, all
we used a node project that used for elasticsearch javascript pacakge ( 14.2.2) which is the latest version.
We have got security audit report by a security firm that based on elasticsearch (14.2.2) for javascript package that it is possible to have CRLF injection issue (Improper Output Neutralization for Logs) on /src/lib/connectors/xhr.js 76
whether it is possible to have a log forging attack by line#76
73:   xhr.onreadystatechange = function () {
74:    if (xhr.readyState === 4) {
75:      clearTimeout(timeoutId);
76:      log.trace(params.method, url, params.body, xhr.responseText, xhr.status);
      var err = xhr.status ? void 0 : new ConnectionFault(xhr.statusText || 'Request failed to complete.');
      cb(err, xhr.responseText, xhr.status);
is it already identified from elasticsearch community ? or any configuration set up to make disable log.trace() ?
The log is just a logger abstraction which can be implemented in many different ways.
If you need extra logic due to security concerns, then you can just implement and use your own logger.
thanks for the information. I set up as below disable trace, only enable for error.
var client = new elasticsearch.Client({ log: 'error' });
Yes, that will also work :slight_smile:
