I have updated ElasticSearch from ver 0.90.3 to ver 1.3.4 ( OS - Debian
Wheezy, deb package version ).
This is a cluster configuration, with 3 nodes connected to unicast.
Update was done with ElasticSearch switched off.
Afters start new verion ElasticSearch cluster health is in 'yellow' state
(showed by head plugin)
( and red state - showed by curl / _cluster / health ).
3 indexes in cluster has 3 unnassigned shards.
Logs from all nodes are lot of informations of "corrupted indexes" or
"sending failed shard for"
Does update to ver 1.4.2 should fix the problem? (Due to lucene libraries
LUCENE-5975 )
Removing index and rereading it is a last thing to do.
ES state from first node:
curl -XGET 'http://127.0.0.1:9200/_cluster/health?pretty=true'
"cluster_name" : "searchcass",
"status" : "red",
"timed_out" : false,
"number_of_nodes" : 3,
"number_of_data_nodes" : 3,
"active_primary_shards" : 283,
"active_shards" : 576,
"relocating_shards" : 0,
"initializing_shards" : 3,
"unassigned_shards" : 3
How can I fix it? Please reply.
Regards
Grzesiek
ES log from node 1 (search01):
[2014-12-17 11:04:20,176][WARN ][cluster.action.shard ] [search01]
[201205][0] received shard failed for [201205][0],
node[OWUJ3lZbT5i00JKgrDFUcw], [P], s[INITIALIZING], indexUUID [na],
reason [master
[search01][HYtX23nPS7uU-DeY-zF6AA][search01][inet[/192.168.199.211:9300]]
marked shard as initializing, but shard is marked as failed, resend shard
failure]
[2014-12-17 11:04:20,253][WARN ][indices.cluster ] [search01]
[201301][0] failed to start shard
org.elasticsearch.index.gateway.IndexShardGatewayRecoveryException:
[201301][0] failed to fetch index version after copying it over
at
org.elasticsearch.index.gateway.local.LocalIndexShardGateway.recover(LocalIndexShardGateway.java:152)
at
org.elasticsearch.index.gateway.IndexShardGatewayService$1.run(IndexShardGatewayService.java:132)
at
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:724)
Caused by: org.apache.lucene.index.CorruptIndexException: [201301][0]
Corrupted index [corrupted_cFQBoZ-WTK2sW8mgUUv1vw] caused by:
CorruptIndexException[did not read all bytes from file: read 9650 vs size
9651 (resource:
BufferedChecksumIndexInput(NIOFSIndexInput(path="/var/lib/elasticsearch/searchcass/nodes/0/indices/201301/0/index/_5f9v_k.del")))]
at org.elasticsearch.index.store.Store.failIfCorrupted(Store.java:353)
at org.elasticsearch.index.store.Store.failIfCorrupted(Store.java:338)
at
org.elasticsearch.index.gateway.local.LocalIndexShardGateway.recover(LocalIndexShardGateway.java:119)
... 4 more
[2014-12-17 11:04:20,279][WARN ][cluster.action.shard ] [search01]
[201304][4] received shard failed for [201304][4],
node[zygoKW7SR6CwvanVoNrPcw], [P], s[INITIALIZING], indexUUID [na],
reason [Failed to start shard, message
[IndexShardGatewayRecoveryException[[201304][4] failed to fetch index
version after copying it over]; nested: CorruptIndexException[[201304][4]
Corrupted index [corrupted_7hrGiX_jTx2KLbQUIAiLpg] caused by:
CorruptIndexException[did not read all bytes from file: read 295641 vs size
295642 (resource:
BufferedChecksumIndexInput(NIOFSIndexInput(path="/var/lib/elasticsearch/searchcass/nodes/0/indices/201304/4/index/_294h_17.del")))]];
[2014-12-17 11:04:20,305][WARN ][cluster.action.shard ] [search01]
reason [master
failure]
[2014-12-17 11:04:20,329][WARN ][cluster.action.shard ] [search01]
[201301][0] sending failed shard for [201301][0],
node[HYtX23nPS7uU-DeY-zF6AA], [P], s[INITIALIZING], indexUUID [na],
[IndexShardGatewayRecoveryException[[201301][0] failed to fetch index
version after copying it over]; nested: CorruptIndexException[[201301][0]
9651 (resource:
BufferedChecksumIndexInput(NIOFSIndexInput(path="/var/lib/elasticsearch/searchcassandra/nodes/0/indices/201301/0/index/_5f9v_k.del")))]];
[201301][0] received shard failed for [201301][0],
9651 (resource:
BufferedChecksumIndexInput(NIOFSIndexInput(path="/var/lib/elasticsearch/searchcass/nodes/0/indices/201301/0/index/_5f9v_k.del")))]];
[2014-12-17 11:04:20,331][WARN ][cluster.action.shard ] [search01]
reason [master
failure]
ES log from node 2 (search02):
[2014-12-17 11:10:11,971][WARN ][cluster.action.shard ] [search02]
Corrupted index [corrupted_U1eBtw3YRYKcfuV9ZHPadw] caused by:
9651 (resource:
[2014-12-17 11:10:12,258][WARN ][indices.cluster ] [search02]
[201205][0] failed to start shard
[201205][0] failed to fetch index version after copying it over
at
at
at
at
Caused by: org.apache.lucene.index.CorruptIndexException: [201205][0]
Corrupted index [corrupted_xCs6wOMpR-G3pbQfUpn-Ww] caused by:
CorruptIndexException[did not read all bytes from file: read 205 vs size
206 (resource:
BufferedChecksumIndexInput(NIOFSIndexInput(path="/var/lib/elasticsearch/searchcass/nodes/0/indices/201205/0/index/_1ys_3.del")))]
at
... 4 more
[2014-12-17 11:10:12,278][WARN ][indices.cluster ] [search02]
[201304][4] failed to start shard
[201304][4] failed to fetch index version after copying it over
at
at
at
at
Caused by: org.apache.lucene.index.CorruptIndexException: [201304][4]
Corrupted index [corrupted_mfMa6wjdT1m6QZ6WUBHKrA] caused by:
295642 (resource:
at
... 4 more
[2014-12-17 11:10:12,282][WARN ][cluster.action.shard ] [search02]
[201205][0] sending failed shard for [201205][0],
[IndexShardGatewayRecoveryException[[201205][0] failed to fetch index
version after copying it over]; nested: CorruptIndexException[[201205][0]
206 (resource:
BufferedChecksumIndexInput(NIOFSIndexInput(path="/var/lib/elasticsearch/searchcass/nodes/0/indices/201205/0/index/_1ys_3.del")))]];
[2014-12-17 11:10:12,297][WARN ][cluster.action.shard ] [search02]
[201304][4] sending failed shard for [201304][4],
295642 (resource:
ES log from node 3 (search03):
2014-12-17 11:13:49,541][WARN ][cluster.action.shard ] [search03]
Corrupted index [corrupted_weSqXhW_T9Wle8wEHhEnXw] caused by:
206 (resource:
[2014-12-17 11:13:49,581][WARN ][indices.cluster ] [search03]
at
at
at
at
295642 (resource:
at
... 4 more
[2014-12-17 11:13:49,651][WARN ][cluster.action.shard ] [search03]
295642 (resource:
[2014-12-17 11:13:49,747][WARN ][indices.cluster ] [search03]
at
at
at
at
206 (resource:
at
... 4 more
[2014-12-17 11:13:49,823][WARN ][cluster.action.shard ] [search03]
206 (resource:
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/746145b6-dd27-468c-af1e-50b4685b1a38%40googlegroups.com.
