I have a cluster of 3 big physical machines (i.e. with a lot of RAM) so I'm hosting multiple nodes on each physical host.
So, I define a node attribute named shard_allocation on each node whose value is the hostname of the physical machine : node.attr.shard_allocation: ${HOSTNAME}
Then I set cluster.routing.allocation.awareness.attributes: shard_allocation so that the cluster prefers to put the same shards on different hosts (to be resilient to the crash of a physical machine)
Note: I cannot use cluster.routing.allocation.same_shard.host: true because nodes on one particular node have the value <hostname>_<nodename> instead of hostname.
For a particular use cases, I want that all the shards of a specific index are available on every nodes.
So I set its replica factor to (number to the number of hosts - 1).
However, some shards stay unassigned.
With the https://<host>:9200/_cluster/allocation/explain endpoint, I get this error message:
"there are too many copies of the shard allocated to nodes with attribute [shard_allocation], there are [16] total configured shard copies for this shard id and [6] total attribute values, expected the allocated shard count per attribute [4] to be less than or equal to the upper bound of the required number of shards per attribute [3]"
Questions:
- do you know if it's possible to disable
cluster.routing.allocation.awareness.attributesfor a specific index? - do you have any suggestion to solve this issue?
Reducing the number of replicas is not a solution because I want the index be present on each node.
Thanks.
