I've document which has Turkish words like "şa, za, sb, şc, sd, şe" etc. as customer_address property.
I've indexed my documents as documented below because I want to order documents according to the customer_address field. Sorting is working well. Sorting and Collations
Now I'm trying to apply range query over "customer_address" field. When I sent the query below, I've got an empty result. (expected result: sb, sd, şa, şd)
`curl -XGET http://localhost:9200/sampleindex/_search?pretty -d '{"query":{"bool":{"filter":[{"range":{"customer_address.sort":{"from":"plaj","to":"şcam","include_lower":true,"include_upper":true,"boost":1.0}}}],"disable_coord":false,"adjust_pure_negative":true,"boost":1.0}}}'`
When I've queried I saw that my fields are encrypted as specified in the document.
curl -XGET http://localhost:9200/sampleindex/_search?pretty -d '{"aggs":{"myaggregation":{"terms":{"field":"customer_address.sort","size":10000}}},"size":0}'
"took" : 5,
"timed_out" : false,
"_shards" : {
"total" : 5,
"successful" : 5,
"failed" : 0
"hits" : {
"total" : 6,
"max_score" : 0.0,
"hits" : [ ]
"aggregations" : {
"a" : {
"doc_count_error_upper_bound" : 0,
"sum_other_doc_count" : 0,
"buckets" : [
"key" : "⚕䁁䀠怀\u0001",
"doc_count" : 1
"key" : "⚗䁁䀠怀\u0001",
"doc_count" : 1
"key" : "✁ੀ⃀ၠ\u0000\u0000",
"doc_count" : 1
"key" : "✁ୀ⃀ၠ\u0000\u0000",
"doc_count" : 1
"key" : "✁ీ⃀ၠ\u0000\u0000",
"doc_count" : 1
"key" : "ⶔ䁁䀠怀\u0001",
"doc_count" : 1
So, How should I send my parameters in the range query to be able to get the successful result?
Thanks in advance.
My Mapping:
curl -XGET http://localhost:9200/sampleindex?pretty
"sampleindex" : {
"aliases" : { },
"mappings" : {
"invoice" : {
"properties" : {
"customer_address" : {
"type" : "text",
"fields" : {
"keyword" : {
"type" : "keyword"
"sort" : {
"type" : "text",
"analyzer" : "turkish",
"fielddata" : true
"settings" : {
"index" : {
"number_of_shards" : "5",
"provided_name" : "sampleindex",
"max_result_window" : "2147483647",
"creation_date" : "1521732167023",
"analysis" : {
"filter" : {
"turkish_phonebook" : {
"variant" : "@collation=phonebook",
"country" : "TR",
"language" : "tr",
"type" : "icu_collation"
"turkish_lowercase" : {
"type" : "lowercase",
"language" : "turkish"
"analyzer" : {
"turkish" : {
"filter" : [
"turkish_lowercase",
"turkish_phonebook"
"tokenizer" : "keyword"
"number_of_replicas" : "1",
"uuid" : "ChNGX459TUi8VnBLTMn-Ng",
"version" : {
"created" : "5020099"
