I am new to Elassandra. I want to make setup(windows 10) and hit queries
from Elasticsearch url. I have installed Elassandra and start it is working
fine but am not able to access Elasticsearch url. I also tried to
configure host and http.port in elasticsearch.yml but it did not work.
From bin am running Cassandra -e. here is no error in logs but still not
able to access ES on localhost:9200
show the following error
curl: (7) Failed to connect to localhost port 9200: Connection refused
Welcome!
I think you might want to ask the Elassandra community. IIRC this project runs a modified version of Elasticsearch.
But maybe share the full Elasticsearch logs here?
if elasticsearch folder doesn't have elasticsearch.bat file how to run the elasticsearch service
No idea. As I said, if the distribution has been modified by a 3rd party, you need to ask them.
