Elasticsearch-hadoop for spark, index documents from a RDD in different index by day: myindex-2014-01-01 for example
I work on a complex workflow using Spark (Parsing, Cleaning, Machine
Learning....).
At the end of the workflow I want to send aggregated results to
elasticsearch so my portal could query data.
There will be two types of processing: streaming and the possibility to
relaunch workflow on all available data.
Right now I use elasticsearch-hadoop and particularly the spark part to
send document to elasticsearch with the saveJsonToEs(myindex, mytype)
method.
The target is to have an index by day using the proper template that we
build.
AFAIK you could not add consideration of a feature in a document to send it
to the proper index in elasticsearch-hadoop.
What is the proper way to implement this feature?
Have a special step useing spark and bulk so that each executor send
documents to the proper index considering the feature of each line?
Is there something that I missed in elasticsearch-hadoop?
Julien
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/58b0e0e3-a297-4cf4-95bf-d3cf34546ea3%40googlegroups.com.
I think I have a solution:
Build JSON files so I could send it directly to _bulk
saveJsonToEs("_bulk")
Not sure if it will be optimized or even worked, I'll try.
On Thursday, January 15, 2015 at 4:17:57 PM UTC+1, Julien Naour wrote:
Learning....).
method.
build.
it to the proper index in elasticsearch-hadoop.
Julien
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/b9bba847-9e64-4336-92d9-80cd52c081d8%40googlegroups.com.
My previous idea doesn't seem to work. Cannot send documents directly to
_bulk only to "index/type" pattern
Learning....).
method.
build.
Julien
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/f01bc8d0-0c04-4c82-8ddf-dc301b06179c%40googlegroups.com.
I implemented a solution for my problem.
I use a foreachPartitions and instantiate a bulk processor using a
transport client (i.e. one by partition) to send documents.
It's not fast but it works.
Somebody have an idea to be more efficient?
Julien
Learning....).
method.
build.
Julien
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/dad84f38-cc36-4351-9d13-e0d1f461ebe9%40googlegroups.com.
Hi Julien,
I'm unclear of what you are trying to achieve and what doesn't work.
es-hadoop allows either a static index/type or a dynamic one [1] [2]. One can also use a 'formatter' so for example
you can use a pattern like "{@timestamp:YYYY-MM-dd}" - meaning the field @timestamp will be used as a target but first
it will formatted into year/month/day.
There's work underway to extend that for API/real-time environments, if the global settings (which are pluggable are not
enough)
like Spark to customize the metadata per entry [3].
Hope this helps,
[1] Elasticsearch Platform — Find real-time answers at scale | Elastic
[2] Elasticsearch Platform — Find real-time answers at scale | Elastic
[3] allow per-doc metadata to be specified at runtime · Issue #358 · elastic/elasticsearch-hadoop · GitHub
I use a foreachPartitions and instantiate a bulk processor using a transport client (i.e. one by partition) to send
documents.
Julien
My previous idea doesn't seem to work. Cannot send documents directly to _bulk only to "index/type" pattern
    I work on a complex workflow using Spark (Parsing, Cleaning, Machine Learning....).
    At the end of the workflow I want to send aggregated results to elasticsearch so my portal could query data.
    There will be two types of processing: streaming and the possibility to relaunch workflow on all available data.
    Right now I use elasticsearch-hadoop and particularly the spark part to send document to elasticsearch with the
    saveJsonToEs(myindex, mytype) method.
    The target is to have an index by day using the proper template that we build.
    AFAIK you could not add consideration of a feature in a document to send it to the proper index in
    Have a special step useing spark and bulk so that each executor send documents to the proper index considering
    Julien
elasticsearch+unsubscribe@googlegroups.com mailto:elasticsearch+unsubscribe@googlegroups.com.
https://groups.google.com/d/msgid/elasticsearch/dad84f38-cc36-4351-9d13-e0d1f461ebe9%40googlegroups.com?utm_medium=email&utm_source=footer.
Costin
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/54BD2062.1050907%40gmail.com.
Thanks for the reply Costin.
I'm not really clear but the basic idea is to index data by day considering
a feature available in each line
Example of data (~700 millions lines for ~90days):
2014-01-01,05,06,ici
2014-01-04,05,06,la
The first one have to be send to my-index-2014-01-01/my-type and the other
my-index-2014-01-04/my-type
I would like to do it without having to launch 90 saveJsonToES (using the
elasticsearch-hadoop spark API)
Is it more clear?
It seems that the dynamic index could work for me. I'll try that right away.
Thanks again
Julien
2015-01-19 16:18 GMT+01:00 Costin Leau costin.leau@gmail.com:
Hi Julien,
the global settings (which are pluggable are not enough)
Hope this helps,
master/configuration.html#cfg-multi-writes
master/spark.html#spark-write-dyn
documents.
Julien
that we build.
    Julien
email to
elasticsearch+unsubscribe@googlegroups.com <mailto:elasticsearch+
unsubscribe@googlegroups.com>.
<https://groups.google.com/d/msgid/elasticsearch/dad84f38-
cc36-4351-9d13-e0d1f461ebe9%40GGGROUPS CASINO – Real Slot Casino for 10,000+ Senior Players
email&utm_source=footer>.
Costin
You received this message because you are subscribed to a topic in the
To unsubscribe from this topic, visit https://groups.google.com/d/
topic/elasticsearch/5-LwjQxVlhk/unsubscribe.
To unsubscribe from this group and all its topics, send an email to
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/CAFGA2c2xpkS5EGYL8yDC%3DkjraR0nHoz0Dhm%2BAdR52GF1NV93jg%40mail.gmail.com.
Ok it works with a simple saveJsonToEs("aft-{date}/analysis")
Thanks Costin
2015-01-19 16:45 GMT+01:00 Julien Naour julnaour@gmail.com:
considering a feature available in each line
2014-01-04,05,06,la
Is it more clear?
away.
Thanks again
Julien
Hi Julien,
Hope this helps,
documents.
Julien
wrote:
that we build.
    Julien
an email to
Costin
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/CAFGA2c3Qpq-Jotr3LefGm%3Dt%3Dcz%3Dk8EjeQMizMOPUT9oe87d3ag%40mail.gmail.com.
Hi Julien,
I am trying to achieve something similar. In my case, my JSON contains a
field "time" in Unix time. And i want to partition my indexes by this
field. That is, if one JSON1 contains 1422904680 in "time" and JSON2
contains 1422991080 in time, then i want to create indexes which are
partitioned by time (24 hours) like
index_1422835200_1422921599 - which will contain JSON1 because value of
"time" = 1422904680 falls in its range.
index_1422921600_1423007999 - which will contain JSON2 because value of
"time" = 1422991080 falls in its range.
Now I want to create my indexes dynamically. There is also possibility of
receiving a JSON which contain a value of time before current date.
To achieve this, I need to create index name dynamically by calculating it
at the time of creation then and there itself. Programmatically, I want to
achieve something like this
JavaEsSpark.saveJsonToEs(jrd, "index_{time} - {time} % 86400}_{ {time} +
86400 - {date} % 86400 }/type");
Is it possible to achieve dynamic index name creation as described above?
If no, is there any work around to achieve my use case.
Abhishek
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/2326fa57-63d9-4b9c-8b71-b1c8b2b0e061%40googlegroups.com.
Hi Abhishek,
I'll probably do a previous step to process the day by line (like
yyyy-MM-dd).
And just do
JavaEsSpark.saveJsonToEs(jrd, "index_{date}/type");
If the range is needed I'll probably do the same. Add a feature with {time}
  • {time} % 86400}{ {time} + 86400 - {date} % 86400 } and just
    index
    {my_new_feature}
It adds a step and a feature in the doc but it's simple to do.
Julien
2015-02-02 15:13 GMT+01:00 Abhishek Patel present.boiling2290@gmail.com:
Hi Julien,
Abhishek
https://groups.google.com/d/topic/elasticsearch/5-LwjQxVlhk/unsubscribe.
https://groups.google.com/d/msgid/elasticsearch/2326fa57-63d9-4b9c-8b71-b1c8b2b0e061%40googlegroups.com?utm_medium=email&utm_source=footer
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/CAFGA2c3fFGtSpTtpR9tD%2BsfwjuRDftHTK7y2QUHUYEhH5iwkWA%40mail.gmail.com.
Hi Julien
Yes. Probably that's the only possible work around to do this. What I am
planning to do is, calculate the name of index prior to writing and add a
field named "indexname" in my JSON and then I will use
JavaEsSpark.saveJsonToEs(jrd, "index_{indexname}/type");
Thanks for the reply.
Abhishek
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/7d41dbce-964c-4c71-94cf-d4dcf0e902b5%40googlegroups.com.
