elasticsearch installation is stuck:Nothing happens after the last log,the security log
[2019-08-16T19:22:17,371][INFO ][o.e.p.PluginsService ] [HPC6] loaded module
[lang-mustache]
[2019-08-16T19:22:17,372][INFO ][o.e.p.PluginsService ] [HPC6] loaded module
[lang-painless]
[2019-08-16T19:22:17,373][INFO ][o.e.p.PluginsService ] [HPC6] loaded module
[mapper-extras]
[2019-08-16T19:22:17,375][INFO ][o.e.p.PluginsService ] [HPC6] loaded module
[parent-join]
[2019-08-16T19:22:17,376][INFO ][o.e.p.PluginsService ] [HPC6] loaded module
[percolator]
[2019-08-16T19:22:17,377][INFO ][o.e.p.PluginsService ] [HPC6] loaded module
[rank-eval]
[2019-08-16T19:22:17,379][INFO ][o.e.p.PluginsService ] [HPC6] loaded module
[reindex]
[2019-08-16T19:22:17,386][INFO ][o.e.p.PluginsService ] [HPC6] loaded module
[repository-url]
[2019-08-16T19:22:17,388][INFO ][o.e.p.PluginsService ] [HPC6] loaded module
[transport-netty4]
[2019-08-16T19:22:17,390][INFO ][o.e.p.PluginsService ] [HPC6] loaded module
[vectors]
[2019-08-16T19:22:17,392][INFO ][o.e.p.PluginsService ] [HPC6] loaded module
[x-pack-ccr]
[2019-08-16T19:22:17,395][INFO ][o.e.p.PluginsService ] [HPC6] loaded module
[x-pack-core]
[2019-08-16T19:22:17,396][INFO ][o.e.p.PluginsService ] [HPC6] loaded module
[x-pack-deprecation]
[2019-08-16T19:22:17,398][INFO ][o.e.p.PluginsService ] [HPC6] loaded module
[x-pack-graph]
[2019-08-16T19:22:17,400][INFO ][o.e.p.PluginsService ] [HPC6] loaded module
[x-pack-ilm]
[2019-08-16T19:22:17,404][INFO ][o.e.p.PluginsService ] [HPC6] loaded module
[x-pack-logstash]
[2019-08-16T19:22:17,405][INFO ][o.e.p.PluginsService ] [HPC6] loaded module
[x-pack-ml]
[2019-08-16T19:22:17,407][INFO ][o.e.p.PluginsService ] [HPC6] loaded module
[x-pack-monitoring]
[2019-08-16T19:22:17,409][INFO ][o.e.p.PluginsService ] [HPC6] loaded module
[x-pack-rollup]
[2019-08-16T19:22:17,411][INFO ][o.e.p.PluginsService ] [HPC6] loaded module
[x-pack-security]
[2019-08-16T19:22:17,415][INFO ][o.e.p.PluginsService ] [HPC6] loaded module
[x-pack-sql]
[2019-08-16T19:22:17,418][INFO ][o.e.p.PluginsService ] [HPC6] loaded module
[x-pack-voting-only-node]
[2019-08-16T19:22:17,422][INFO ][o.e.p.PluginsService ] [HPC6] loaded module
[x-pack-watcher]
[2019-08-16T19:22:17,427][INFO ][o.e.p.PluginsService ] [HPC6] no plugins lo
aded
[2019-08-16T19:22:57,515][INFO ][o.e.x.s.a.s.FileRolesStore] [HPC6] parsed [0] r
oles from file [D:\elastic\elasticsearch-7.3.0\config\roles.yml]
[2019-08-16T19:23:16,460][INFO ][o.e.x.m.p.l.CppLogMessageHandler] [HPC6] [contr
oller/533932] [Main.cc@110] controller (64 bit): Version 7.3.0 (Build ff2f774f78
ce63) Copyright (c) 2019 Elasticsearch BV
[2019-08-16T19:23:28,063][DEBUG][o.e.a.ActionModule ] [HPC6] Using REST wr
apper from plugin org.elasticsearch.xpack.security.Security
[2019-08-16T19:23:33,299][INFO ][o.e.d.DiscoveryModule ] [HPC6] using discove
ry type [zen] and seed hosts providers [settings]
[2019-08-16T19:23:40,522][INFO ][o.e.n.Node ] [HPC6] initialized
[2019-08-16T19:23:40,524][INFO ][o.e.n.Node ] [HPC6] starting ...
[2019-08-16T19:23:49,071][INFO ][o.e.t.TransportService ] [HPC6] publish_addre
ss {127.0.0.1:9300}, bound_addresses {127.0.0.1:9300}, {[::1]:9300}
[2019-08-16T19:23:49,109][WARN ][o.e.b.BootstrapChecks ] [HPC6] the default d
iscovery settings are unsuitable for production use; at least one of [discovery.
seed_hosts, discovery.seed_providers, cluster.initial_master_nodes] must be conf
igured
[2019-08-16T19:23:49,196][INFO ][o.e.c.c.ClusterBootstrapService] [HPC6] no disc
overy configuration found, will perform best-effort cluster bootstrapping after
[3s] unless existing master is discovered
[2019-08-16T19:23:52,256][INFO ][o.e.c.c.Coordinator ] [HPC6] setting initi
al configuration to VotingConfiguration{E3oCgnjWSnitsSpwt3JhOA}
[2019-08-16T19:23:53,076][INFO ][o.e.c.s.MasterService ] [HPC6] elected-as-ma
ster ([1] nodes joined)[{HPC6}{E3oCgnjWSnitsSpwt3JhOA}{N95aTGkbRryLzSHFZOdnBQ}{1
27.0.0.1}{127.0.0.1:9300}{dim}{ml.machine_memory=8506232832, xpack.installed=tru
e, ml.max_open_jobs=20} elect leader, BECOME_MASTER_TASK, FINISH_ELECTION],
term: 1, version: 1, reason: master node changed {previous , current [{HPC6}{E
3oCgnjWSnitsSpwt3JhOA}{N95aTGkbRryLzSHFZOdnBQ}{127.0.0.1}{127.0.0.1:9300}{dim}{m
l.machine_memory=8506232832, xpack.installed=true, ml.max_open_jobs=20}]}
[2019-08-16T19:23:53,395][INFO ][o.e.c.c.CoordinationState] [HPC6] cluster UUID
set to [ovcjlyDaRPKmE1uR5xkqow]
[2019-08-16T19:23:53,536][INFO ][o.e.c.s.ClusterApplierService] [HPC6] master no
de changed {previous , current [{HPC6}{E3oCgnjWSnitsSpwt3JhOA}{N95aTGkbRryLzSH
FZOdnBQ}{127.0.0.1}{127.0.0.1:9300}{dim}{ml.machine_memory=8506232832, xpack.ins
talled=true, ml.max_open_jobs=20}]}, term: 1, version: 1, reason: Publication{te
rm=1, version=1}
[2019-08-16T19:23:54,937][INFO ][o.e.g.GatewayService ] [HPC6] recovered [0]
indices into cluster_state
[2019-08-16T19:23:55,353][INFO ][o.e.h.AbstractHttpServerTransport] [HPC6] publi
sh_address {127.0.0.1:9200}, bound_addresses {127.0.0.1:9200}, {[::1]:9200}
[2019-08-16T19:23:55,356][INFO ][o.e.n.Node ] [HPC6] started
[2019-08-16T19:23:56,731][INFO ][o.e.c.m.MetaDataIndexTemplateService] [HPC6] ad
ding template [.watch-history-10] for index patterns [.watcher-history-10*]
[2019-08-16T19:23:57,184][INFO ][o.e.c.m.MetaDataIndexTemplateService] [HPC6] ad
ding template [.watches] for index patterns [.watches*]
[2019-08-16T19:23:57,358][INFO ][o.e.c.m.MetaDataIndexTemplateService] [HPC6] ad
ding template [.triggered_watches] for index patterns [.triggered_watches*]
[2019-08-16T19:23:57,617][INFO ][o.e.c.m.MetaDataIndexTemplateService] [HPC6] ad
ding template [.monitoring-logstash] for index patterns [.monitoring-logstash-7-
[2019-08-16T19:23:57,926][INFO ][o.e.c.m.MetaDataIndexTemplateService] [HPC6] ad
ding template [.monitoring-es] for index patterns [.monitoring-es-7-]
[2019-08-16T19:23:58,210][INFO ][o.e.c.m.MetaDataIndexTemplateService] [HPC6] ad
ding template [.monitoring-beats] for index patterns [.monitoring-beats-7-]
[2019-08-16T19:23:58,410][INFO ][o.e.c.m.MetaDataIndexTemplateService] [HPC6] ad
ding template [.monitoring-alerts-7] for index patterns [.monitoring-alerts-7]
[2019-08-16T19:23:58,566][INFO ][o.e.c.m.MetaDataIndexTemplateService] [HPC6] ad
ding template [.monitoring-kibana] for index patterns [.monitoring-kibana-7-]
[2019-08-16T19:23:58,703][INFO ][o.e.x.i.a.TransportPutLifecycleAction] [HPC6] a
dding index lifecycle policy [watch-history-ilm-policy]
[2019-08-16T19:23:59,335][INFO ][o.e.l.LicenseService ] [HPC6] license [dfd9
f0c4-5248-4d45-869f-836c1bb88d55] mode [basic] - valid
[2019-08-16T19:23:59,338][INFO ][o.e.x.s.s.SecurityStatusChangeListener] [HPC6]
Active license is now [BASIC]; Security is disabled
have you tried reaching your elasticsearch cluster? It looks as if it is up and running.
The log message is just logging, that security is not enabled, which is fine, unless you did so in the configuration file.
