Hi, I was running the tests with:
./gradlew --continue test
My environment variables are:
JAVA_HOME=/usr/local/jdk-13.0.2+8/
JAVA13_HOME=/usr/local/jdk-13.0.2+8/
RUNTIME_JAVA_HOME is not set.
I noticed that only while executing the tests, it downloads another instance of the JDK and places it in
elasticsearch/build/jdks/adoptopenjdk-13.0.2_linux
Then it seems to run all the tests against that instance, instead of the system one.
Previously to running the tests, I built a packaged version with the system installed JDK.
I was expecting/hoping to run the tests against the same instance.
I looked through the code and found these two snippets:
In buildSrc/src/main/java/org/elasticsearch/gradle/info/GlobalBuildInfoPlugin.java
public class GlobalBuildInfoPlugin implements Plugin<Project> {
public void apply(Project project) {
File compilerJavaHome = findCompilerJavaHome();
File runtimeJavaHome = findRuntimeJavaHome(compilerJavaHome);
// Initialize global build parameters
BuildParams.init(params -> {
params.setIsRutimeJavaHomeSet(compilerJavaHome.equals(runtimeJavaHome) == false);
and in gradle/runtime-jdk-provision.gradle
configure(allprojects - project(':build-tools')) {
project.tasks.withType(Test).configureEach { Test test ->
if (BuildParams.getIsRuntimeJavaHomeSet()) {
test.executable = "${BuildParams.runtimeJavaHome}/bin/java"
} else {
test.dependsOn(rootProject.jdks.provisioned_runtime)
test.executable = rootProject.jdks.provisioned_runtime.getBinJavaPath()
It looks like if you have a different runtime java set in RUNTIME_JAVA_HOME then the tests run against the system installed instance of that version. However, in the case where you either don't have that variable set, or your JAVA_HOME is set to the same value as RUNTIME_JAVA_HOME then it downloads the 'exact' same version and tests against that one.
I'm not sure if this is a bug, or intended?
The JDK that it downloads does not run on the system I'm on, so all the tests fail out of hand when trying to do:
command 'elasticsearch/build/jdks/adoptopenjdk-13.0.2_linux/bin/java -version'
Is there a work around that I'm missing? Another way to make sure it uses the system runtime java?
