I attached test case into the ticket:
Regards,
Lukas
Regards,
Lukas
just pushed a fix for this, can you test it?
Add the ability to store the index name in the doc · Issue #292 · elastic/elasticsearch · GitHubRegards,
Lukas
So, I reindex my data and I can see with Luke that "_index" field is in
index now, cool. However, my query still returns empty terms : array for
the "index" facet. What am I doing wrong? And am I using it correctly at
all? Is "_index" supposed to work the same way in facets as "_type"?
Here is the query:
curl -XGET 'http://localhost:9200/foo/bar/_search?pretty=1' -d '
"size" : 1,
"query" : { "match_all":{}},
"facets" : {
"type" : {
"terms" : { "field" : "_type"}
"index" : {
"terms" : { "field" : "_index" }
Here is output:
"_shards" : {
"total" : 1,
"successful" : 1,
"failed" : 0
"hits" : {
"total" : 3,
"max_score" : 1.0,
"hits" : [ {
"_index" : "foo",
"_type" : "bar",
"_id" : "1",
"_score" : 1.0, "_source" : {"field1":"value1","field2":"1"}
"facets" : {
"type" : {
"_type" : "terms",
"_field" : "_type",
"terms" : [ {
"term" : "bar",
"count" : 3
"index" : {
"_type" : "terms",
"_field" : "_index",
"terms" :
On Mon, Aug 9, 2010 at 7:32 PM, Shay Banon shay.banon@elasticsearch.comwrote:
Lukas
I've ran your script in the case and I do get back the terms for the index,
here is what I get:
{"error":"[foo]
missing"}{"ok":true,"acknowledged":true}{"ok":true,"acknowledged":true}{"ok":true,"_index":"foo","_type":"bar","_id":"1"}{"ok":true,"_index":"foo","_type":"bar","_id":"2"}{"ok":true,"_index":"foo","_type":"bar","_id":"3"}{"ok":true,"_shards":{"total":1,"successful":1,"failed":0}}{
"_shards" : {
"total" : 1,
"successful" : 1,
"failed" : 0
"hits" : {
"total" : 3,
"max_score" : 1.0,
"hits" :
"facets" : {
"type" : {
"_type" : "terms",
"_field" : "_type",
"terms" : [ {
"term" : "bar",
"count" : 3
"index" : {
"_type" : "terms",
"terms" : [ {
"term" : "foo",
"count" : 3
all? Is "_index" supposed to work the same way in facets as "_type"?Here is the query:
"size" : 1,
"facets" : {
"type" : {
"index" : {
}'Here is output:
"_shards" : {
"total" : 1,
"successful" : 1,
"failed" : 0
"hits" : {
"total" : 3,
"max_score" : 1.0,
"hits" : [ {
"_index" : "foo",
"_type" : "bar",
"_id" : "1",
"facets" : {
"type" : {
"_type" : "terms",
"_field" : "_type",
"terms" : [ {
"term" : "bar",
"count" : 3
"index" : {
"_type" : "terms",
"terms" :
}On Mon, Aug 9, 2010 at 7:32 PM, Shay Banon shay.banon@elasticsearch.comwrote:
Lukas
Excellent, it works for me as well now. I changed mappings in my test script
and had a bug there. Sorry about that.
On Mon, Aug 9, 2010 at 8:49 PM, Shay Banon shay.banon@elasticsearch.comwrote:
here is what I get:{"error":"[foo]
"_shards" : {
"total" : 1,
"successful" : 1,
"failed" : 0
"hits" : {
"total" : 3,
"max_score" : 1.0,
"hits" :
"facets" : {
"type" : {
"_type" : "terms",
"_field" : "_type",
"terms" : [ {
"term" : "bar",
"count" : 3
"index" : {
"_type" : "terms",
"terms" : [ {
"term" : "foo",
"count" : 3
"size" : 1,
"facets" : {
"type" : {
"index" : {
}'Here is output:
"_shards" : {
"total" : 1,
"successful" : 1,
"failed" : 0
"hits" : {
"total" : 3,
"max_score" : 1.0,
"hits" : [ {
"_index" : "foo",
"_type" : "bar",
"_id" : "1",
"facets" : {
"type" : {
"_type" : "terms",
"_field" : "_type",
"terms" : [ {
"term" : "bar",
"count" : 3
"index" : {
"_type" : "terms",
"terms" :
Lukas
