Error "Look-behind group does not have an obvious maximum length near index" in pattern_capture
Hello
I just want to index the word "Samsung" in the text below
Text: Samsung a30 mobile phone
I mean I want to separate the text above by space and just index the word I want (the word may change by location, for example I might want to index the third or second word of the text)
I use pattern_capture to do this
Pattern: (?<=^(\W+\s){1})(\w+)
But I get the following error
Error:
  "error" : {
    "root_cause" : [
        "type" : "pattern_syntax_exception",
        "reason" : "Look-behind group does not have an obvious maximum length near index 14\n(?<=^(\\w+\\s){1})(\\w+)\n              ^"
  "status" : 400
Do you have a solution?
To do this you must use the predicate_token_filter filter
Sample code:
GET /_analyze
  "tokenizer": "whitespace",
  "filter": [
      "type": "predicate_token_filter",
      "script": {
        "source": """
          token.getPosition() === 0
  "text": "the fox jumps the lazy dog"
