Error trying to index products
When trying to index products, 80000, after a few seconds the following error message appears:
[PrestaShop] Fatal error in module file :/var/www/xxxxxx.es/modules/elasticsearchpro/vendor/elasticsearch/elasticsearch/src/Elasticsearch/Connections/Connection.php:
Uncaught Elasticsearch\Common\Exceptions\BadRequest400Exception in /var/www/xxxxxx.es/modules/elasticsearchpro/vendor/elasticsearch/elasticsearch/src/Elasticsearch/Connections/Connection.php:610 Stack trace: #0 /var/www/xxxxxx.es/modules/elasticsearchpro/vendor/elasticsearch/elasticsearch/src/Elasticsearch/Connections/Connection.php(273): Elasticsearch\Connections\Connection->process4xxError(Array, Array, Array) #1 /var/www/xxxxxx.es/modules/elasticsearchpro/vendor/react/promise/src/FulfilledPromise.php(25): Elasticsearch\Connections\Connection->Elasticsearch\Connections\{closure}(Array) #2 /var/www/xxxxxx.es/modules/elasticsearchpro/vendor/guzzlehttp/ringphp/src/Future/CompletedFutureValue.php(55): React\Promise\FulfilledPromise->then(Object(Closure), NULL, NULL) #3 /var/www/xxxxxx.es/modules/elasticsearchpro/vendor/guzzlehttp/ringphp/src/Core.php(341): GuzzleHttp\Ring\Future\CompletedFutureValue->then(Object(Closure), NULL, NULL) #4 /var/www/xxxxxx.es/modules/
Elastic Search version: 6.6.1
Configured in Ubuntu 16.04
java version "1.8.0_201"
Java(TM) SE Runtime Environment (build 1.8.0_201-b09)
Java HotSpot(TM) 64-Bit Server VM (build 25.201-b09, mixed mode)
Prestashop 1.6.1.23
Thank you.
That seems to be a problem in the Prestashop codebase so I would recommend contacting them as that might give you an answer faster.
