Hello all,
Stupid problem over here im sure... i just cant place the finger on it... If you could point me to the problem it would be greatly apreciated.
heres the template :
curl -XPUT 'http://localhost:9200/_template/ftg' -d '
  "order" : 0,
  "template": "ftg-*",
  "settings" : {
    "index.refresh_interval" : "5s"
    "index.number_of_replicas" : 0
    "index.codec" : "best_compression"
    "number_of_shards" : 5
  "mappings" : {
    "_default_" : {
       "_all" : { "enabled" : false },
       "dynamic_templates" : [ {
         "message_field" : {
           "match" : "message",
           "match_mapping_type" : "string",
           "mapping" : {
             "type" : "string", "index" : "analyzed", "omit_norms" : true,
             "fields" : {
              "raw" : {"type": "string", "index" : "not_analyzed", "ignore_above" : 256}
         "string_fields" : {
           "match" : "*",
           "mapping" : {
               "fields" : {
"properties" : {
         "@version": { "type": "string", "index": "not_analyzed" },
         "geoip"  : {
           "type" : "object",
             "dynamic": true,
             "properties" : {
               "location" : { "type" : "geo_point" }
im sure the problem is pretty dumb, but I keep getting error code 34, execting a comma... Cant find where.
please pretty please ?
thank you
