ES fails to start with error index has more than one write index
There was an ES cluster which was running for a while but suddenly docker got restarted and all nodes started to fail with below error:
"stacktrace": ["org.elasticsearch.bootstrap.StartupException: java.lang.IllegalStateException: alias [my-extension-2019.09-write] has more than one write index [my-extension-2019.09-000011,my-extension-2019.09-000017]",
Anyway I can clean up the same or start the cluster.. Also as this does not have an ID otherwise I could have deleted that particular folder from data/nodes/0/indices..
Would be great of someone can help on same.
(Apologies for the original lack of response.)
For future note when searched, this is now answered in the blog Troubleshooting ILM blog with the direct summary quote:
When you run Get Aliases, you’ll notice that two indices are marked as is_write_index:true when only one should be per alias. You’ll want to toggle is_write_index:false on one of the indices via the Aliases API.
