We've been using ES for the last two months, slowly, getting ready to
start using it into production.
We have roughly 24m documents, on 3 machines, 24G, 24 core, 4 disk SSD
RAID 0 in each. Index size is roughly 36G in total. JVM is given up to
18G per machine.
we have it set up into two indexes, one that is using 6 shards and 1
replica with 16m documents, and one that is using 12 shards and 1
replica with about 350,000 documents. (We are basically rebuilding the
first index into the second). Benchmarking we can get about 100 q/s
per machine when it's doing nothing else, so we like that. I have many
shards as the number of items I expect to go into here is about
150-500m.
We are having the following issues and I'm looking for some tips on
debugging:
First, the documents aren't evenly shared, I have 24M, 16M, and 8M on
different machines. If I bring it down to two machines, it's even
16/16 - is that odd, or expected? I thought it would always be equal
across the 3.
Every day or so, one of the machines spikes quickly (in a matter of
minutes), runs out of memory, and basically becomes unresponsive. We
then see the other two basically spike, and sometimes they recover,
and often, they don't. This is while I'm running queries against it -
if they aren't being queried against, and I take a node down, they
rebalance in a matter of minutes and all is happy. We access
everything through PyES.
I'm really looking for ways to debug what's going on - the logs aren't
that useful, I see out of memory on one, and then the loss of
connection to it from the others - I can post some if it would be
useful. We did see one stack trace (once) that may showed the stack
in a delete, but that may have just been random.
And while I'm at it, anyone (Shay?
do ES consulting to potentially
work with us to figure out what's going on?
Here's the two shards:
"ok" : true,
"_shards" : {
"total" : 6,
"successful" : 6,
"failed" : 0
"indices" : {
"legacy_places" : {
"index" : {
"primary_size" : "19gb",
"primary_size_in_bytes" : 20476411666,
"size" : "38.1gb",
"size_in_bytes" : 40952823332
"translog" : {
"operations" : 0
"docs" : {
"num_docs" : 24370334,
"max_doc" : 24385103,
"deleted_docs" : 14769
"merges" : {
"current" : 0,
"current_docs" : 0,
"current_size" : "0b",
"current_size_in_bytes" : 0,
"total" : 0,
"total_time" : "0s",
"total_time_in_millis" : 0,
"total_docs" : 0,
"total_size" : "0b",
"total_size_in_bytes" : 0
"refresh" : {
"total" : 0,
"flush" : {
"total" : 187,
"total_time" : "138ms",
"total_time_in_millis" : 138
"shards" : {
"0" : [ {
"routing" : {
"state" : "STARTED",
"primary" : true,
"node" : "pNWhe9zmQjCxw2b7SIJTdw",
"relocating_node" : null,
"shard" : 0,
"index" : "legacy_places"
"index" : {
"size" : "6.1gb",
"size_in_bytes" : 6656257213
"translog" : {
"id" : 1323890905623,
"operations" : 0
"docs" : {
"num_docs" : 7917088,
"max_doc" : 7921473,
"deleted_docs" : 4385
"merges" : {
"current" : 0,
"current_docs" : 0,
"total" : 0,
"total_docs" : 0,
"refresh" : {
"total" : 0,
"flush" : {
"total" : 32,
"total_time" : "25ms",
"total_time_in_millis" : 25
"routing" : {
"primary" : false,
"node" : "VMc1uC1uRUCnxCZTzE4S9A",
"shard" : 0,
"index" : {
"size" : "6.1gb",
"translog" : {
"operations" : 0
"docs" : {
"merges" : {
"current" : 0,
"current_docs" : 0,
"total" : 0,
"total_docs" : 0,
"refresh" : {
"total" : 0,
"flush" : {
"total" : 31,
"total_time" : "24ms",
"total_time_in_millis" : 24
"1" : [ {
"routing" : {
"primary" : false,
"shard" : 1,
"index" : {
"size" : "6.4gb",
"size_in_bytes" : 6954949268
"translog" : {
"id" : 1323890905917,
"operations" : 0
"docs" : {
"num_docs" : 8257213,
"max_doc" : 8262908,
"deleted_docs" : 5695
"merges" : {
"current" : 0,
"current_docs" : 0,
"total" : 0,
"total_docs" : 0,
"refresh" : {
"total" : 0,
"flush" : {
"total" : 31,
"routing" : {
"primary" : true,
"shard" : 1,
"index" : {
"size" : "6.4gb",
"translog" : {
"operations" : 0
"docs" : {
"merges" : {
"current" : 0,
"current_docs" : 0,
"total" : 0,
"total_docs" : 0,
"refresh" : {
"total" : 0,
"flush" : {
"total" : 31,
"2" : [ {
"routing" : {
"primary" : false,
"node" : "NHx8JgLkSD-IMuff8c349A",
"shard" : 2,
"index" : {
"size" : "6.3gb",
"size_in_bytes" : 6865205185
"translog" : {
"id" : 1323890905928,
"operations" : 0
"docs" : {
"num_docs" : 8196033,
"max_doc" : 8200722,
"deleted_docs" : 4689
"merges" : {
"current" : 0,
"current_docs" : 0,
"total" : 0,
"total_docs" : 0,
"refresh" : {
"total" : 0,
"flush" : {
"total" : 31,
"total_time" : "22ms",
"total_time_in_millis" : 22
"routing" : {
"primary" : true,
"shard" : 2,
"index" : {
"size" : "6.3gb",
"translog" : {
"operations" : 0
"docs" : {
"merges" : {
"current" : 0,
"current_docs" : 0,
"total" : 0,
"total_docs" : 0,
"refresh" : {
"total" : 0,
"flush" : {
"total" : 31,
"total_time" : "19ms",
"total_time_in_millis" : 19
And the smaller one:
"ok" : true,
"_shards" : {
"total" : 12,
"successful" : 12,
"failed" : 0
"indices" : {
"places" : {
"index" : {
"primary_size" : "287.3mb",
"primary_size_in_bytes" : 301304028,
"size" : "574.6mb",
"size_in_bytes" : 602608056
"translog" : {
"operations" : 0
"docs" : {
"num_docs" : 328917,
"max_doc" : 370550,
"deleted_docs" : 41633
"merges" : {
"current" : 0,
"current_docs" : 0,
"total" : 0,
"total_docs" : 0,
"refresh" : {
"total" : 0,
"flush" : {
"total" : 372,
"total_time" : "140ms",
"total_time_in_millis" : 140
"shards" : {
"0" : [ {
"routing" : {
"primary" : false,
"shard" : 0,
"index" : "places"
"index" : {
"size" : "44.9mb",
"size_in_bytes" : 47116017
"translog" : {
"id" : 1324591339645,
"operations" : 0
"docs" : {
"num_docs" : 52001,
"max_doc" : 58573,
"deleted_docs" : 6572
"merges" : {
"current" : 0,
"current_docs" : 0,
"total" : 0,
"total_docs" : 0,
"refresh" : {
"total" : 0,
"flush" : {
"total" : 31,
"total_time" : "13ms",
"routing" : {
"primary" : true,
"shard" : 0,
"index" : "places"
"index" : {
"size" : "44.9mb",
"translog" : {
"operations" : 0
"docs" : {
"num_docs" : 52001,
"max_doc" : 58573,
"merges" : {
"current" : 0,
"current_docs" : 0,
"total" : 0,
"total_docs" : 0,
"refresh" : {
"total" : 0,
"flush" : {
"total" : 31,
"total_time" : "12ms",
"total_time_in_millis" : 12
"1" : [ {
"routing" : {
"primary" : true,
"shard" : 1,
"index" : "places"
"index" : {
"size" : "43.5mb",
"size_in_bytes" : 45616358
"translog" : {
"id" : 1324591339818,
"operations" : 0
"docs" : {
"num_docs" : 50991,
"max_doc" : 55917,
"deleted_docs" : 4926
"merges" : {
"current" : 0,
"current_docs" : 0,
"total" : 0,
"total_docs" : 0,
"refresh" : {
"total" : 0,
"flush" : {
"total" : 31,
"total_time" : "10ms",
"total_time_in_millis" : 10
"routing" : {
"primary" : false,
"shard" : 1,
"index" : "places"
"index" : {
"size" : "43.5mb",
"translog" : {
"operations" : 0
"docs" : {
"num_docs" : 50991,
"max_doc" : 55917,
"merges" : {
"current" : 0,
"current_docs" : 0,
"total" : 0,
"total_docs" : 0,
"refresh" : {
"total" : 0,
"flush" : {
"total" : 31,
"2" : [ {
"routing" : {
"primary" : true,
"shard" : 2,
"index" : "places"
"index" : {
"size" : "54.7mb",
"size_in_bytes" : 57375684
"translog" : {
"id" : 1324591339466,
"operations" : 0
"docs" : {
"num_docs" : 60920,
"max_doc" : 70373,
"deleted_docs" : 9453
"merges" : {
"current" : 0,
"current_docs" : 0,
"total" : 0,
"total_docs" : 0,
"refresh" : {
"total" : 0,
"flush" : {
"total" : 31,
"routing" : {
"primary" : false,
"shard" : 2,
"index" : "places"
"index" : {
"size" : "54.7mb",
"translog" : {
"operations" : 0
"docs" : {
"num_docs" : 60920,
"max_doc" : 70373,
"merges" : {
"current" : 0,
"current_docs" : 0,
"total" : 0,
"total_docs" : 0,
"refresh" : {
"total" : 0,
"flush" : {
"total" : 31,
"total_time" : "15ms",
"total_time_in_millis" : 15
"3" : [ {
"routing" : {
"primary" : true,
"shard" : 3,
"index" : "places"
"index" : {
"size" : "45.4mb",
"size_in_bytes" : 47665161
"translog" : {
"id" : 1324591339663,
"operations" : 0
"docs" : {
"num_docs" : 52301,
"max_doc" : 58879,
"deleted_docs" : 6578
"merges" : {
"current" : 0,
"current_docs" : 0,
"total" : 0,
"total_docs" : 0,
"refresh" : {
"total" : 0,
"flush" : {
"total" : 31,
"routing" : {
"primary" : false,
"shard" : 3,
"index" : "places"
"index" : {
"size" : "45.4mb",
"translog" : {
"operations" : 0
"docs" : {
"num_docs" : 52301,
"max_doc" : 58879,
"merges" : {
"current" : 0,
"current_docs" : 0,
"total" : 0,
"total_docs" : 0,
"refresh" : {
"total" : 0,
"flush" : {
"total" : 31,
"total_time" : "14ms",
"4" : [ {
"routing" : {
"primary" : true,
"shard" : 4,
"index" : "places"
"index" : {
"size" : "44.1mb",
"size_in_bytes" : 46278154
"translog" : {
"id" : 1324591339839,
"operations" : 0
"docs" : {
"num_docs" : 51625,
"max_doc" : 56555,
"deleted_docs" : 4930
"merges" : {
"current" : 0,
"current_docs" : 0,
"total" : 0,
"total_docs" : 0,
"refresh" : {
"total" : 0,
"flush" : {
"total" : 31,
"total_time" : "11ms",
"total_time_in_millis" : 11
"routing" : {
"primary" : false,
"shard" : 4,
"index" : "places"
"index" : {
"size" : "44.1mb",
"translog" : {
"operations" : 0
"docs" : {
"num_docs" : 51625,
"max_doc" : 56555,
"merges" : {
"current" : 0,
"current_docs" : 0,
"total" : 0,
"total_docs" : 0,
"refresh" : {
"total" : 0,
"flush" : {
"total" : 31,
"5" : [ {
"routing" : {
"primary" : true,
"shard" : 5,
"index" : "places"
"index" : {
"size" : "54.6mb",
"size_in_bytes" : 57252654
"translog" : {
"id" : 1324591339578,
"operations" : 0
"docs" : {
"num_docs" : 61079,
"max_doc" : 70253,
"deleted_docs" : 9174
"merges" : {
"current" : 0,
"current_docs" : 0,
"total" : 0,
"total_docs" : 0,
"refresh" : {
"total" : 0,
"flush" : {
"total" : 31,
"total_time" : "6ms",
"total_time_in_millis" : 6
"routing" : {
"primary" : false,
"shard" : 5,
"index" : "places"
"index" : {
"size" : "54.6mb",
"translog" : {
"operations" : 0
"docs" : {
"num_docs" : 61079,
"max_doc" : 70253,
"merges" : {
"current" : 0,
"current_docs" : 0,
"total" : 0,
"total_docs" : 0,
"refresh" : {
"total" : 0,
"flush" : {
"total" : 31,
"total_time" : "7ms",
"total_time_in_millis" : 7
John Cwikla
VPE
fwix
