I am getting above error when i am trying to start metricbeat. please help to resolve this issue
Well... you need to provide more reference points. Which operating system are you running on? Which Beats version? Do you have dbus installed?
Thank you for your reply,
i am using windows 10 aws instance.& metricbeat 7.9.1. No i dont have dbus installed in my aws instance
hi @Shriram_Wasule, the load metricset is only available for linux systems since load averages are considered linux specific. You will have to disable the load metricset option inside the system.yml config file.
