i'm having a problem like this: Logstash on K8S spammed with Connection Reset By Peer
does anyone know how to solve?
My LS logs
[2020-02-17T15:27:20,062][INFO ][org.logstash.beats.BeatsHandler][main] [local: 0.0.0.0:5044, remote: undefined] Handling exception: Connection reset by peer
[2020-02-17T15:27:20,074][WARN ][io.netty.channel.DefaultChannelPipeline][main] An exceptionCaught() event was fired, and it reached at the tail of the pipeline. It usually means the last handler in the pipeline did not handle the exception.
java.io.IOException: Connection reset by peer
at sun.nio.ch.FileDispatcherImpl.read0(Native Method) ~[?:?]
at sun.nio.ch.SocketDispatcher.read(SocketDispatcher.java:39) ~[?:?]
at sun.nio.ch.IOUtil.readIntoNativeBuffer(IOUtil.java:276) ~[?:?]
at sun.nio.ch.IOUtil.read(IOUtil.java:233) ~[?:?]
at sun.nio.ch.IOUtil.read(IOUtil.java:223) ~[?:?]
at sun.nio.ch.SocketChannelImpl.read(SocketChannelImpl.java:358) ~[?:?]
at io.netty.buffer.PooledUnsafeDirectByteBuf.setBytes(PooledUnsafeDirectByteBuf.java:288) ~[netty-all-4.1.30.Final.jar:4.1.30.Final]
at io.netty.buffer.AbstractByteBuf.writeBytes(AbstractByteBuf.java:1128) ~[netty-all-4.1.30.Final.jar:4.1.30.Final]
at io.netty.channel.socket.nio.NioSocketChannel.doReadBytes(NioSocketChannel.java:347) ~[netty-all-4.1.30.Final.jar:4.1.30.Final]
at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:148) ~[netty-all-4.1.30.Final.jar:4.1.30.Final]
at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:644) ~[netty-all-4.1.30.Final.jar:4.1.30.Final]
at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:579) ~[netty-all-4.1.30.Final.jar:4.1.30.Final]
at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:496) ~[netty-all-4.1.30.Final.jar:4.1.30.Final]
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:458) [netty-all-4.1.30.Final.jar:4.1.30.Final]
at io.netty.util.concurrent.SingleThreadEventExecutor$5.run(SingleThreadEventExecutor.java:897) [netty-all-4.1.30.Final.jar:4.1.30.Final]
at io.netty.util.concurrent.FastThreadLocalRunnable.run(FastThreadLocalRunnable.java:30) [netty-all-4.1.30.Final.jar:4.1.30.Final]
at java.lang.Thread.run(Thread.java:834) [?:?]
My FB logs
|2020-02-17T15:27:51.572-0300|INFO|pipeline/output.go:95|Connecting to backoff(async(tcp://150.161.11.114:5044))|
|2020-02-17T15:27:51.574-0300|INFO|pipeline/output.go:105|Connection to backoff(async(tcp://150.161.11.114:5044)) established|
|2020-02-17T15:27:51.577-0300|ERROR|logstash/async.go:256|Failed to publish events caused by: read tcp 150.161.0.4:38711->150.161.11.114:5044: read: connection reset by peer|
|2020-02-17T15:27:51.581-0300|ERROR|logstash/async.go:256|Failed to publish events caused by: client is not connected|
There was some blocking on the firewall, because I was trying to communicate on different subnets, which I couldn't identify.
Tried on the same subnet worked normally.
