Failed to query elasticsearch for previous event {:query=>"_index:s1index AND type:a AND A:1 ",....:error=>#<NoMethodError: undefined method `start_with?' for nil:NilClass>, :level=>:warn}
Hi
I have two csv files , s1.csv with following data,
1,2,3
1,2,3
2,3,4
And s2.csv with following data,
1,4
2,5
Consider column name as specified in configuration files like for s1 - A,B,C and for s2 Aa,Bb
Now I want to add new field called "Bbb" and copy "Bb" column from s2 file to s1 event by matching A = Aa. so I want to get following result
1,2,3,4
1,2,3,4
2,3,4,5
logstash-sample1.conf with following configuration
file {
path => "/home/workload/s1.csv"
start_position => "beginning"
stat_interval => 30
type => "a"
if ([type] == "a") {
csv {
columns => ["A","B","C"]
separator => ","
convert => {"A"=>"integer"}
convert => {"B"=>"integer"}
convert => {"C" => "integer"}
action => "index"
index => "s1index"
hosts => "10.0.1.73"
stdout {
codec=>"rubydebug"
And logstash-sample2.conf with following
file {
path => "/home/workload/s2.csv"
stat_interval => 30
type => "b"
if ([type] == "b") {
csv {
columns => ["Aa","Bb"]
separator => ","
convert => {"Aa"=>"integer"}
convert => {"Bb"=>"integer"}
hosts => ["centrifyfw2"]
query => "_index:s1index AND type:a AND A:%{[Aa]} "
fields => ["B", "Bbb"]
stdout {
codec=>"rubydebug"
I am getting following error
Starting pipeline {:id=>"base", :pipeline_workers=>4, :batch_size=>125, :batch_delay=>5, :max_inflight=>500, :level=>:info}
Pipeline started {:level=>:info}
Logstash startup completed
Failed to query elasticsearch for previous event {:query=>"_index:s1index AND type:a AND A:1 ", :event=>#<LogStash::Event:0x193eed2b @metadata_accessors=#<LogStash::Util::Accessors:0x1de75774 @store={"path"=>"/home/workload/s2.csv"}, @lut={"[path]"=>[{"path"=>"/home/workload/s2.csv"}, "path"]}>, @cancelled=false, @data={"message"=>"1,4\r", "@version"=>"1", "@timestamp"=>"2016-04-13T13:17:38.436Z", "path"=>"/home/workload/s2.csv", "host"=>"centrifyfw2", "type"=>"b", "Aa"=>1, "Bb"=>4}, @metadata={"path"=>"/home/workload/s2.csv"}, @accessors=#<LogStash::Util::Accessors:0x184abbb @store={"message"=>"1,4\r", "@version"=>"1", "@timestamp"=>"2016-04-13T13:17:38.436Z", "path"=>"/home/workload/s2.csv", "host"=>"centrifyfw2", "type"=>"b", "Aa"=>1, "Bb"=>4}, @lut={"path"=>[{"message"=>"1,4\r", "@version"=>"1", "@timestamp"=>"2016-04-13T13:17:38.436Z", "path"=>"/home/workload/s2.csv", "host"=>"centrifyfw2", "type"=>"b", "Aa"=>1, "Bb"=>4}, "path"], "host"=>[{"message"=>"1,4\r", "@version"=>"1", "@timestamp"=>"2016-04-13T13:17:38.436Z", "path"=>"/home/workload/s2.csv", "host"=>"centrifyfw2", "type"=>"b", "Aa"=>1, "Bb"=>4}, "host"], "type"=>[{"message"=>"1,4\r", "@version"=>"1", "@timestamp"=>"2016-04-13T13:17:38.436Z", "path"=>"/home/workload/s2.csv", "host"=>"centrifyfw2", "type"=>"b", "Aa"=>1, "Bb"=>4}, "type"], "[type]"=>[{"message"=>"1,4\r", "@version"=>"1", "@timestamp"=>"2016-04-13T13:17:38.436Z", "path"=>"/home/workload/s2.csv", "host"=>"centrifyfw2", "type"=>"b", "Aa"=>1, "Bb"=>4}, "type"], "message"=>[{"message"=>"1,4\r", "@version"=>"1", "@timestamp"=>"2016-04-13T13:17:38.436Z", "path"=>"/home/workload/s2.csv", "host"=>"centrifyfw2", "type"=>"b", "Aa"=>1, "Bb"=>4}, "message"], "[Aa]"=>[{"message"=>"1,4\r", "@version"=>"1", "@timestamp"=>"2016-04-13T13:17:38.436Z", "path"=>"/home/workload/s2.csv", "host"=>"centrifyfw2", "type"=>"b", "Aa"=>1, "Bb"=>4}, "Aa"], "[Bb]"=>[{"message"=>"1,4\r", "@version"=>"1", "@timestamp"=>"2016-04-13T13:17:38.436Z", "path"=>"/home/workload/s2.csv", "host"=>"centrifyfw2", "type"=>"b", "Aa"=>1, "Bb"=>4}, "Bb"]}>>, :error=>#<NoMethodError: undefined method `start_with?' for nil:NilClass>, :level=>:warn}
"message" => "1,4\r",
"@version" => "1",
"@timestamp" => "2016-04-13T13:17:38.436Z",
"path" => "/home/workload/s2.csv",
"host" => "centrifyfw2",
"type" => "b",
"Aa" => 1,
"Bb" => 4
Failed to query ..
"message" => "2,5\r",
"@version" => "1",
"@timestamp" => "2016-04-13T13:17:38.603Z",
"type" => "b",
"Aa" => 2,
"Bb" => 5
How to resolve it?
In the subject field you mention a NoMethodError error. Please show the complete logs surrounding that.
As there is limit to subject text I put "Failed to query elasticsearch for previous event {:query=>”_index:s1index AND type:a AND A:1 “,….:error=>#<NoMethodError: undefined method `start_with?’ for nil:NilClass>, :level=>:warn}" in subject
Well, is there a NoMethodError error message in your logs? Then post the full context of it. What you've included in the body of your post never mentions NoMethodError.
Yes. There is NoMethodError error message in logs. Here is log.
Registering file input {:path=>["/home/workload/s2.csv"], :level=>:info}
No sincedb_path set, generating one based on the file path {:sincedb_path=>"/root/.sincedb_5cdf64f518cc8621047416ef3996332c", :path=>["/home/workload/s2.csv"], :level=>:info}
New ElasticSearch filter {:hosts=>["centrifyfw2"], :level=>:info}
Failed to query elasticsearch for previous event {:query=>"_index:s1index AND type:a AND A:1 ", :event=>#<LogStash::Event:0x193eed2b @metadata_accessors=#<LogStash::Util::Accessors:0x1de75774 @store={"path"=>"/home/workload/s2.csv"}, @lut={"[path]"=>[{"path"=>"/home/workload/s2.csv"}, "path"]}>, @cancelled=false, @data={"message"=>"1,4\r", "@version"=>"1", "@timestamp"=>"2016-04-13T13:17:38.436Z", "path"=>"/home/workload/s2.csv", "host"=>"centrifyfw2", "type"=>"b", "Aa"=>1, "Bb"=>4}, @metadata={"path"=>"/home/workload/s2.csv"}, @accessors=#<LogStash::Util::Accessors:0x184abbb @store={"message"=>"1,4\r", "@version"=>"1", "@timestamp"=>"2016-04-13T13:17:38.436Z", "path"=>"/home/workload/s2.csv", "host"=>"centrifyfw2", "type"=>"b", "Aa"=>1, "Bb"=>4}, @lut={"path"=>[{"message"=>"1,4\r", "@version"=>"1", "@timestamp"=>"2016-04-13T13:17:38.436Z", "path"=>"/home/workload/s2.csv", "host"=>"centrifyfw2", "type"=>"b", "Aa"=>1, "Bb"=>4}, "path"], "host"=>[{"message"=>"1,4\r", "@version"=>"1", "@timestamp"=>"2016-04-13T13:17:38.436Z", "path"=>"/home/workload/s2.csv", "host"=>"centrifyfw2", "type"=>"b", "Aa"=>1, "Bb"=>4}, "host"], "type"=>[{"message"=>"1,4\r", "@version"=>"1", "@timestamp"=>"2016-04-13T13:17:38.436Z", "path"=>"/home/workload/s2.csv", "host"=>"centrifyfw2", "type"=>"b", "Aa"=>1, "Bb"=>4}, "type"], "[type]"=>[{"message"=>"1,4\r", "@version"=>"1", "@timestamp"=>"2016-04-13T13:17:38.436Z", "path"=>"/home/workload/s2.csv", "host"=>"centrifyfw2", "type"=>"b", "Aa"=>1, "Bb"=>4}, "type"], "message"=>[{"message"=>"1,4\r", "@version"=>"1", "@timestamp"=>"2016-04-13T13:17:38.436Z", "path"=>"/home/workload/s2.csv", "host"=>"centrifyfw2", "type"=>"b", "Aa"=>1, "Bb"=>4}, "message"], "[Aa]"=>[{"message"=>"1,4\r", "@version"=>"1", "@timestamp"=>"2016-04-13T13:17:38.436Z", "path"=>"/home/workload/s2.csv", "host"=>"centrifyfw2", "type"=>"b", "Aa"=>1, "Bb"=>4}, "Aa"], "[Bb]"=>[{"message"=>"1,4\r", "@version"=>"1", "@timestamp"=>"2016-04-13T13:17:38.436Z", "path"=>"/home/workload/s2.csv", "host"=>"centrifyfw2", "type"=>"b", "Aa"=>1, "Bb"=>4}, "Bb"]}>>, :error=>#NoMethodError: undefined method `start_with?' for nil:NilClass, :level=>:warn}
"@version" => "1",
"type" => "b",
"Aa" => 1,
"Bb" => 4
But the log snippet you just posted doesn't contain the word NoMethodError.
Please check it again.
Hi
I have the same logstash.log error with NoMethodError .
here the conf files:
beats {
port => 5044
ssl => false
ssl_certificate => "/etc/pki/tls/certs/logstash-forwarder.crt"
ssl_key => "/etc/pki/tls/private/logstash-forwarder.key"
if [type] == "conn" {
grok {
tag_on_failure => ["connlog_long_parse_fail"]
match => {"message" => [ ".?\s+.?\s+(?<src_ip>\d+.\d+.\d+.\d+)\s\S+\s(?<dst_ip>\d+.\d+.\d+.\d+)"] }
hosts => ["localhost"]
query => "type:maltrail AND dst_ip:%{dst_ip}"
fields => [ "reason" ]
geoip {
source => "src_ip"
target => "geoip"
database => "/etc/logstash/GeoLiteCity.dat"
add_field => [ "[geoip][coordinates]", "%{[geoip][longitude]}" ]
add_field => [ "[geoip][coordinates]", "%{[geoip][latitude]}" ]
geoip {
source => "dst_ip"
target => "geoip"
mutate {
convert => [ "[geoip][coordinates]", "float"]
date {
match => [ "syslog_timestamp", "MMM d HH:mm:ss", "MMM dd HH:mm:ss" ]
hosts => ["localhost:9200"]
sniffing => true
manage_template => false
sniffing => true
there's the log-
{:timestamp=>"2016-07-18T09:10:18.083000+0300", :message=>"Failed to query elasticsearch for previous event", :index=>"", :query=>"type:maltrail AND dst_ip:172.16.1.10", :event=>#<LogStash::Event:0x51b7e5c7 @metadata_accessors=#<LogStash::Util::Accessors:0x6e95d2e7 @store={"type"=>"conn", "beat"=>"filebeat"}, @lut={}>, @cancelled=false, @data={"message"=>"1468822199.963471\tC3gEHk1b9GOQXYX5Z3\t172.17.1.2\t45124\t172.16.1.10\t53\tudp\tdns\t0.026759\t0\t506\tSHR\tT\tT\t0\tCd\t0\t0\t1\t534\t(empty)\t-\t-\t#siftworkstation-eth0", "@version"=>"1", "@timestamp"=>"2016-07-18T06:10:17.432Z", "type"=>"conn", "source"=>"/nsm/bro/logs/current/conn.log", "count"=>1, "fields"=>nil, "beat"=>{"hostname"=>"siftworkstation", "name"=>"siftworkstation"}, "offset"=>504473, "input_type"=>"log", "host"=>"siftworkstation", "tags"=>["beats_input_codec_plain_applied"], "syslog_severity_code"=>5, "syslog_facility_code"=>1, "syslog_facility"=>"user-level", "syslog_severity"=>"notice", "src_ip"=>"172.17.1.2", "dst_ip"=>"172.16.1.10"}, @metadata={"type"=>"conn", "beat"=>"filebeat"}, @accessors=#<LogStash::Util::Accessors:0x2669ac33 @store={"message"=>"1468822199.963471\tC3gEHk1b9GOQXYX5Z3\t172.17.1.2\t45124\t172.16.1.10\t53\tudp\tdns\t0.026759\t0\t506\tSHR\tT\tT\t0\tCd\t0\t0\t1\t534\t(empty)\t-\t-\t#siftworkstation-eth0", "@version"=>"1", "@timestamp"=>"2016-07-18T06:10:17.432Z", "type"=>"conn", "source"=>"/nsm/bro/logs/current/conn.log", "count"=>1, "fields"=>nil, "beat"=>{"hostname"=>"siftworkstation", "name"=>"siftworkstation"}, "offset"=>504473, "input_type"=>"log", "host"=>"siftworkstation", "tags"=>["beats_input_codec_plain_applied"], "syslog_severity_code"=>5, "syslog_facility_code"=>1, "syslog_facility"=>"user-level", "syslog_severity"=>"notice", [{"message"=>"1468822199.963471\tC3gEHk1b9GOQXYX5Z3\t172.17.1.2\t45124\t172.16.1.10\t53\tudp\tdns\t0.026759\t0\t506\tSHR\tT\tT\t0\tCd\t0\t0\t1\t534\t(empty)\t-\t-\t#siftworkstation-eth0", "@version"=>"1", "@timestamp"=>"2016-07-18T06:10:17.432Z", "type"=>"conn", "source"=>"/nsm/bro/logs/current/conn.log", "count"=>1, "fields"=>nil, "beat"=>{"hostname"=>"siftworkstation", "name"=>"siftworkstation"}, "offset"=>504473, "input_type"=>"log", "host"=>"siftworkstation", "tags"=>["beats_input_codec_plain_applied"], "syslog_severity_code"=>5, "syslog_facility_code"=>1, "syslog_facility"=>"user-level", "syslog_severity"=>"notice", "src_ip"=>"172.17.1.2", "dst_ip"=>"172.16.1.10"}, "src_ip"]}>>, :error=>#<NoMethodError: undefined method `start_with?' for nil:NilClass>, :level=>:warn}
[{"message"=>"1468822626.133305\tCv3pcx65PJ07Jdv25\t172.17.1.2\t37239\t172.16.1.10\t53\tudp\tdns\t0.027748\t0\t506\tSHR\tT\tT\t0\tCd\t0\t0\t1\t534\t(empty)\t-\t-\t#siftworkstation-eth0", "@version"=>"1", "@timestamp"=>"2016-07-18T06:17:17.440Z", "source"=>"/nsm/bro/logs/current/conn.log", "offset"=>505790, "input_type"=>"log", "count"=>1, "beat"=>{"hostname"=>"siftworkstation", "name"=>"siftworkstation"}, "type"=>"conn", "fields"=>nil, "host"=>"siftworkstation", "tags"=>["beats_input_codec_plain_applied"], "syslog_severity_code"=>5, "syslog_facility_code"=>1, "syslog_facility"=>"user-level", "syslog_severity"=>"notice", "src_ip"=>"172.17.1.2", "dst_ip"=>"172.16.1.10"}, "src_ip"]}>>, :error=>#<NoMethodError: undefined method start_with?' for nil:NilClass>, :level=>:warn} {:timestamp=>"2016-07-18T09:17:20.595000+0300", :message=>"Failed to query elasticsearch for previous event", :index=>"", :query=>"type:maltrail AND dst_ip:172.16.1.10", :event=>#<LogStash::Event:0x4b653d18 @metadata_accessors=#<LogStash::Util::Accessors:0x614d158e @store={"type"=>"conn", "beat"=>"filebeat"}, @lut={}>, @cancelled=false, @data={"message"=>"1468822626.137517\tCJ06wGBTIOaRavwR2\t172.17.1.2\t50456\t172.16.1.10\t53\tudp\tdns\t0.035619\t0\t1008\tSHR\tT\tT\t0\tCd\t0\t0\t2\t1064\t(empty)\t-\t-\t#siftworkstation-eth0", "@version"=>"1", "@timestamp"=>"2016-07-18T06:17:17.440Z", "source"=>"/nsm/bro/logs/current/conn.log", "type"=>"conn", "input_type"=>"log", "count"=>1, "fields"=>nil, "beat"=>{"hostname"=>"siftworkstation", "name"=>"siftworkstation"}, "offset"=>505938, "host"=>"siftworkstation", "tags"=>["beats_input_codec_plain_applied"], "syslog_severity_code"=>5, "syslog_facility_code"=>1, "syslog_facility"=>"user-level", "syslog_severity"=>"notice", "src_ip"=>"172.17.1.2", "dst_ip"=>"172.16.1.10"}, @metadata={"type"=>"conn", "beat"=>"filebeat"}, @accessors=#<LogStash::Util::Accessors:0x5f71b8e1 @store={"message"=>"1468822626.137517\tCJ06wGBTIOaRavwR2\t172.17.1.2\t50456\t172.16.1.10\t53\tudp\tdns\t0.035619\t0\t1008\tSHR\tT\tT\t0\tCd\t0\t0\t2\t1064\t(empty)\t-\t-\t#siftworkstation-eth0", "@version"=>"1", "@timestamp"=>"2016-07-18T06:17:17.440Z", "source"=>"/nsm/bro/logs/current/conn.log", "type"=>"conn", "input_type"=>"log", "count"=>1, "fields"=>nil, "beat"=>{"hostname"=>"siftworkstation", "name"=>"siftworkstation"}, "offset"=>505938, "host"=>"siftworkstation", "tags"=>["beats_input_codec_plain_applied"], "syslog_severity_code"=>5, "syslog_facility_code"=>1, "syslog_facility"=>"user-level", "syslog_severity"=>"notice", "src_ip"=>"172.17.1.2", "dst_ip"=>"172.16.1.10"}, @lut={"@timestamp"=>[{"message"=>"1468822626.137517\tCJ06wGBTIOaRavwR2\t172.17.1.2\t50456\t172.16.1.10\t53\tudp\tdns\t0.035619\t0\t1008\tSHR\tT\tT\t0\tCd\t0\t0\t2\t1064\t(empty)\t-\t-\t#siftworkstation-eth0", "@version"=>"1", "@timestamp"=>"2016-07-18T06:17:17.440Z", "source"=>"/nsm/bro/logs/current/conn.log", "type"=>"conn", "input_type"=>"log", "count"=>1, "fields"=>nil, "beat"=>{"hostname"=>"siftworkstation", "name"=>"siftworkstation"}, "offset"=>505938, "host"=>"siftworkstation", "tags"=>["beats_input_codec_plain_applied"], "syslog_severity_code"=>5, "syslog_facility_code"=>1, "syslog_facility"=>"user-level", "syslog_severity"=>"notice", "src_ip"=>"172.17.1.2", "dst_ip"=>"172.16.1.10"}, "@timestamp"], "source"=>[{"message"=>"1468822626.137517\tCJ06wGBTIOaRavwR2\t172.17.1.2\t50456\t172.16.1.10\t53\tudp\tdns\t0.035619\t0\t1008\tSHR\tT\tT\t0\tCd\t0\t0\t2\t1064\t(empty)\t-\t-\t#siftworkstation-eth0", "@version"=>"1", "@timestamp"=>"2016-07-18T06:17:17.440Z", "source"=>"/nsm/bro/logs/current/conn.log", "type"=>"conn", "input_type"=>"log", "count"=>1, "fields"=>nil, "beat"=>{"hostname"=>"siftworkstation", "name"=>"siftworkstation"}, "offset"=>505938, "host"=>"siftworkstation", "tags"=>["beats_input_codec_plain_applied"], "syslog_severity_code"=>5, "syslog_facility_code"=>1, "syslog_facility"=>"user-level", "syslog_severity"=>"notice", "src_ip"=>"172.17.1.2", "dst_ip"=>"172.16.1.10"}, "source"], "type"=>[{"message"=>"1468822631.454374\tCfj4LIvtsNP39EI4\t172.17.1.2\t33237\t172.16.1.10\t53\tudp\tdns\t0.012831\t0\t1008\tSHR\tT\tT\t0\tCd\t0\t0\t2\t1064\t(empty)\t-\t-\t#siftworkstation-eth0", "@version"=>"1", "@timestamp"=>"2016-07-18T06:17:24.440Z", "fields"=>nil, "beat"=>{"hostname"=>"siftworkstation", "name"=>"siftworkstation"}, "offset"=>506088, "type"=>"conn", "input_type"=>"log", "source"=>"/nsm/bro/logs/current/conn.log", "count"=>1, "host"=>"siftworkstation", "tags"=>["beats_input_codec_plain_applied"], "syslog_severity_code"=>5, "syslog_facility_code"=>1, "syslog_facility"=>"user-level", "syslog_severity"=>"notice", "src_ip"=>"172.17.1.2", "dst_ip"=>"172.16.1.10"}, "src_ip"]}>>, :error=>#<NoMethodError: undefined methodstart_with?' for nil:NilClass>, :level=>:warn}
