Dear all
I'm sending log data to elastic using filebeat. I have multiple files to read, actually I'm sending all log files (eg. *.log) and it works correctly, I have index and rollover works.
Now I need to have different index for different log type and I'm following
this guide
I setup the configuration:
setup.template.settings:
index.number_of_shards: 1
setup.ilm.rollover_alias: "filebeat-test-7.10.2"
setup.ilm.enabled: true
setup.ilm.pattern: "{now/d}-000001"
setup.ilm.policy_name: "filebeat-test-7.10.2"
setup.ilm.overwrite: false
setup.ilm.check_exists: true
output.elasticsearch:
hosts: ["els-mon1.local.com","els-mon2.local.com","els-mon3.local.com"]
index: "filebeat-%{[agent.version]}-%{+yyyy.MM.dd}"
protocol: "https"
username: "filebeat_setup"
password: ""
indices:
- index: "filebeat-test-%{[agent.version]}-api-%{+yyyy.MM.dd}"
when.contains:
message: "webapi"
setup.ilm.rollover_alias: "filebeat-test-7.10.2-api"
setup.ilm.policy_name: "filebeat-test-7.10.2-api"
setup.template:
pattern: "filebeat-test-7.10.2-api-*"
enabled: true
overwrite: false
- index: "filebeat-test-%{[agent.version]}-noapi-%{+yyyy.MM.dd}"
when.contains:
message: "webapps"
setup.template:
pattern: "filebeat-test-7.10.2-*"
enabled: true
overwrite: false
I have correctly 3 different indexes
filebeat-test-7.10.2-2021.02.19
filebeat-test-7.10.2-api-2021.02.19
filebeat-test-7.10.2-noapi-2021.02.19
but only the firstone correctly apply rollover, the problem is rollover alias, It is possible to assign multiple rollover alias to the same ILM?
Or for each index I have to setup a new ilm with new Alias?
Some one have an idea to solve it?
best regards and thanks for your time
P.S. I know that many information are hardcoded into the configuration file I'll fix them when I'll solve the main problem
