Thank you for your response.
I've read about it and you're right, it's exactly what I'm looking for, thank you.
However, I've run into a new issue when I try to execute my query.
This is currently how my Query looks like:
var result = await _client.SearchAsync<TitleDocument>(req =>
req.Index(_indices.Value.Titles)
.Query(q => q
.Bool(b =>
// Handle Cast filtering
b.Filter(f => f
.TermsSet(t => t
.Field(t => t.Cast)
.MinimumShouldMatch("required_matches")
.Terms(query.Cast.Select(id => (FieldValue)id.ToString()).ToList())
When I run the code and try it out, it throws an exception. Logs in the Microsoft Visual Studio Debug Console:
[13:57:31 ERR] Failed to process query SearchTitleQuery with error:
Invalid Elasticsearch response built from an unsuccessful (400) low level call on POST: /manasa-vod-titles/_search
Exception: Request failed to execute.
Call: Status code 400 from: POST /manasa-vod-titles/_search.
ServerError:
Type: x_content_parse_exception
Reason: "[1:73] [bool] failed to parse field [filter]"
CausedBy:
Type: parsing_exception
Reason: "[terms_set] query does not support [minimum_should_match]"
# Audit trail of this API call:
- [1] BadResponse: Node: http://192.168.0.100:9200/
Took: 00:00:00.1260109
# OriginalException:
Elastic.Transport.TransportException:
ServerError:
CausedBy:
# Request:
<Request stream not captured or already read to completion by serializer.
Set DisableDirectStreaming() on TransportConfiguration to force it to be set on the response.>
# Response:
"error": {
"root_cause": [
"type": "parsing_exception",
"reason": "[terms_set] query does not support [minimum_should_match]",
"line": 1,
"col": 73
"type": "x_content_parse_exception",
"reason": "[1:73] [bool] failed to parse field [filter]",
"caused_by": {
"line": 1,
I get the same thing when using .MinimumShouldMatch(2) (integer) instead of MinimumShouldMatch("required_matches") (string.)
If I try to remove it, this the query looks like this:
.Query(q => q
.Bool(b =>
b.Filter(f => f
.TermsSet(t => t
.Field(t => t.Cast)
I get this error in the same debug console:
[14:11:32 ERR] Failed to process query SearchTitleQuery with error
ServerError:
Type: search_phase_execution_exception
Reason: "all shards failed"
Took: 00:00:00.1269650
ServerError:
# Request:
# Response:
"error": {
"root_cause": [
"type": "query_shard_exception",
"reason": "failed to create query: No minimum should match has been specified",
"index_uuid": "f1_veTjSShKNAhQC969CKg",
"index": "manasa-vod-titles"
"type": "search_phase_execution_exception",
"reason": "all shards failed",
"phase": "query",
"grouped": true,
"failed_shards": [
"shard": 0,
"index": "manasa-vod-titles",
"node": "AQ--wA-fQOiWVZPuoW8Iwg",
"reason": {
"caused_by": {
"type": "illegal_state_exception",
"reason": "No minimum should match has been specified"
"status": 400
Reading the terms set query I'm assuming I perhaps have to add a minimum field inside the TitleDocument itself, and with every new document put in the database, but I'm not sure if that's the case, and if it was, I'm not sure how to do that, or how would that look like...
Thank you
