Hi Costin,
I saw a different behavior of creating task for write to ES operation while
working on my project. The difference is as follows:
1.) Only write to ES - When I create an RDD of my own to insert data into
ES, the task are created based on property "es.batch.size.bytes" and
"es.batch.size.entries". Number of task created = Number of documents in
RDD/the value of either of these properties. The request hits the node and
node decides the shard to which document needs routed based on routing
value(if specified).
2.) Read-Update-write to ES - Consider this case when I have to read data
from ES, store it in RDD, do some updates in the documents in RDD and then
index these documents back to ES. While reading, the number of tasks are
created on basis of number of shards and I presume that each tasks fetch
data from each Shard(not sure of how it works? - Task delagting request to
node to serve data from a particular shard?). Now when I try to
update/re-index data using same RDD and function saveToESWithMetadata, this
time the number of task created is a number which is not based on point 1.
If the data in each partition is less than property
"es.batch.size.entries", it creates the same number of tasks as are the
number of shards, else greater than it.
What's the reason behind this? Also like read operation where request is
from particular shard, does write operation also write to a shard or all
the task delegate their request to the node?
Thanks in advance
Piyush Costin,
Thanks in advance
Piyush
Please update your bookmarks! We moved to https://discuss.elastic.co/
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/ec268e76-6220-430b-958a-884692283ca0%40googlegroups.com.
