Help: Format The Watcher Email Body Section
Hi there:
I'm currently using this code {{ctx.payload.payload_result}} in my email body to print out the health check status but the format is not ideal (see below), is there a way I can organize it nicely(see proposed output)? Thanks so much.
"payload_result": {
          "summary": {
            "unavailable": {
              "system1-health-check-status": [
                "system1-host"
              "system2-health-check-status": [
                "system2-host"
              "system3-health-check-status": [
                "system3-host"
              "system4-health-check-status": [
                "system4-host"
              "system5-health-check-status": [
                "system5-host"
Proposed Output:
 -system1-host
 -system2-host
 -system3-host
 -system4-host
 -system5-host
You can loop through a list in your payload result and then do some formatting...
Can you share what you tried so far, because I am only seeing JSON here, which does not help too much from my perspective.
Thanks!
