Help me: Unable to parse response body for Bulk Request posted
Error Details:
java.io.IOException: Unable to parse response body for Response{requestLine=POST /_bulk?timeout=1m HTTP/1.1, host=eu-west-1.es.amazonaws.com, response=HTTP/1.1 200 OK}
Tried to investigate and I see the object send is org.elasticsearch.action.bulk.Response rather than the expected is org.elasticsearch.action.bulk.BulkResponse
Looked into the documentations as well but no luck.
Some important information on dependency and es method we are trying to execute from our Spring Boot Application:
java 11
spring-boot-starter-parent 2.5.6
spring-data-elasticsearch 4.2.6
elasticsearch-rest-high-level-client 7.12.1
org.elasticsearch 7.12.1
code: BulkResponse bulkResponse = elasticsearchClient.bulk(bulkRequest,RequestOptions.DEFAULT);
Welcome!
According to the URL, you are not using Elasticsearch 7.12.1 but another distribution which is not supported here. You must ask your vendor about this.
BTW did you look at Cloud by Elastic, also available if needed from AWS Marketplace, Azure Marketplace and Google Cloud Marketplace?
Cloud by elastic is one way to have access to all features, all managed by us. Think about what is there yet like Vector Search, Security, Monitoring, Reporting, SQL, Canvas, Maps UI, Alerting and built-in solutions named Observability, Security and what is coming next :slight_smile: ...
