Help on using stored filed in side a query
I have index1 and index2. Running below query against Index1 where i point to index2. In indexs those fields created with stored option. Please help on this query.
POST /Index1/_search
        "bool": {
            "filter": [
			"terms" : {
			"PID" : {
			     "index" : "Index2",
				  "type" : "_doc",
				  "id" : "1123",
				  "path" : "field1",
				  "stored": true
ERROR: :{"type":"x_content_parse_exception","reason":"[12:17] [terms_lookup] unknown field [stored]"}
That sounds a lot like a join, which Elasticsearch generally do not support.
What does the data in the two indices look like and how are you looking to merge them?
